Rebuilding a pony motor
Showing 1 to 10 of 11 results
chriscokid
Cat Yellow1
Send a private message to Cat Yellow1
Thanks for posting Erik. I'm in the process of rebuilding mine.
Wed, Nov 20, 2019 4:45 PM
You make it look so easy........next thing you'll be wearing one of those CAT white coats!
Very nicely done.......Thanks!
Wed, Nov 20, 2019 7:50 PM
chriscokid
I take no credit, I am only sharing what I found
Thu, Nov 21, 2019 6:31 AM
oldbeek
Reply to chriscokid:
Very detailed video. 2 things I would add. When inserting the pistons, I always put a rubber sleeve over the rod bolts to protect nicking the crank. ALSO when reinstalling the poney, I put wood blocks, a tad taller than the studs, on top of the mounting surface. Then I unhook lifting device and lower the engine down using pry bars. Saves bumped studs and scuffed gaskets. Didn't see the hard part that is installing safety wires on the rod nuts.
Thu, Nov 21, 2019 9:33 AM
sheddcanyon
Send a private message to sheddcanyon
Thanks a lot. We're in the middle of rebuilding the pony for our 1941 D6 and now I feel compelled to repaint::tsk:
Did you use high-heat paint or regular paint? It sure looks pretty.
Thank you for the videos. That much more motivation to get ours going.
Thu, Nov 21, 2019 11:39 AM
Reply to sheddcanyon:
Unless I missed it, but how did you set the clearance for the crank and main bearings?
Fri, Nov 22, 2019 9:04 AM
Anyone know who Lineshaft Restorations is? I gather its not chriscokid.
Time to take credit for some really nice work and videos to show it.
Fri, Nov 22, 2019 10:39 AM
TomTrack44
Send a private message to TomTrack44
I really like your green chain hoist! Nice videos, thank you for sharing! Tom
Fri, Nov 22, 2019 11:26 AM
[quote="ccjersey"]Anyone know who Lineshaft Restorations is? I gather its not chriscokid.
Time to take credit for some really nice work and videos to show it.[/quote]
Just going strictly off memory "chriscokid" owns a Construction business down South that a few years ago got broken into and a couple of Trucks were stolen? I remember chatting with him at the National Show here, seems like a pretty down to earth fellow?
Lineshaft? I seem to think he is from someplace West of me?
Fri, Nov 22, 2019 7:25 PM
chriscokid
Reply to drujinin:
It's not me, I just happened upon the vids on YouTube and thought you guys might enjoy.
Fri, Nov 22, 2019 8:48 PM
Newby Hall Tractor Fest
