Should be another tag on the LH rear of the engine, just below the cylinder head.
Chances are you have an 85J 955K loader made in USA. Check where OM stated but some of the little later tractors have a different SN engine than the tractor so check above the draw bar first and all that I remember had the SN stamped in the housing if the plate was missing and was directly behind where the plate was riveted on so take a lok there if the plate is missing.
i found some numbers on the motor 61H1445 does anyone know what year it would be im looking for final drive parts
thanks for the info guys
That would be a 1967 model...they only produced a couple thousand 61H's, as opposed to the 12,000 85J's covering 1968 - 78.
Does anyone know if the final drive parts from a 85j will fit the 61h my left side outer case is in pieces i can see the pionon gear and the bearing
thanks again for the help
