Articulated dump truck rental
Showing 1 to 10 of 11 results
ETD66SS
Send a private message to ETD66SS
My Ford L8000 is getting beat to hell digging my ponds. Also, the dirt sticks in the box, and traction is a problem with the slightest rain, so very frustrating to use for this kind of work.
I'm not sure I can afford to rent an articulated 6 wheel drive, but I'm considering it because it just keeps raining here in WNY, and I can't do anything without a dump.
The red outlined area is basically what I have left to dig this summer:
[img]http://usera.imagecave.com/whitedwarf3/Final-Shape/Outline.JPG[/img]
I calculate I have about 5000 cu-yd to excavate. (Yellow hatched area)
[img]http://usera.imagecave.com/etd66ss/More-to-dig/Left-to-dig.JPG[/img]
Do any of you guys rent out articulating dumps? For comparison, what are your weekly rates? How much fuel do these things use? How big/small of a truck should I rent?
I use a CAT 225 to excavate with. It's only myself and my father who can operate machinery like this, and my father refuses to try the 225, so basically one man digging, the other waiting for the truck to fill up, then me waiting with the 225 at idle while the load is dumped. I know, not very efficient, but it is what it is...
Thu, Jun 26, 2008 6:14 PM
Billy D7 4T
Send a private message to Billy D7 4T
You can appreciate the higher prices of fuel and related increases as time progresses, it does usually pay to be efficient and to bang out a job if at all possible.
You may want to consider an expedited game plan, it could save you vs. absorbing the escalated costs later on.
30 cu, yd. articulated dump will work, a pair would be ideal for cycle time, depends on how far the material is being hauled. You'd be better off with a 235, or say a 350 + size machine with a large bucket on for one of these, 225 is a little small for cycle time, though I realize you'll have to make it work, remember the fuel you are burning, slow production with higher fuel consumption. With the money you have invested in this thing, the time and dealing with weather related delays, you may want to consider rental equipment to bang it out and be done, will stop the clock on escalated costs and may prove to be cost effective just to be done.
I'm not sure but most of these are 30 yd capacity, I've run komatsu's and volvo's of that size in the past, not sure of the fuel efficiency. Now they'll run circles around a tandem dump, these were 15 speed models, and I was using a 350L to load em out. You will have to get used to backing them, it's like a trailer, but by habit you will try to back em like a straight truck, have to remember the articulation part. They'll run in soft areas, but you do not want to ever get one stuck with a full load on, well you can dump off, but the suction is strong, one young inexperienced guy drove one right into a clearly marked off borrow pit filled with soft material, fully loaded, even after we unloaded him, it took 2 D8K's hooked onto the back at the same time to get him out, that also included digging out the sides with an excavator, they'll run in soft material, as long as it's not a deep pit pumping up water. Larger excavator will give you the reach and capacity to be efficient, I'd crunch the rental numbers on a larger excavator, a pair of artculated dumps, 1 operator and whatever you need vs. slower production and escalation and see whats what, at this point of the job, I'd be hard pressed to get it done even if that meant financing the way prices are going, pay now or pay more later.
That site looks manageable, but I hear you on the rain, we keep getting thunderstorms, everyday for a few weeks now, certainly slows things down.
Thu, Jun 26, 2008 7:56 PM
ETD66SS
Reply to Billy D7 4T:
[quote="Billy D7 4T"]You can appreciate the higher prices of fuel and related increases as time progresses, it does usually pay to be efficient and to bang out a job if at all possible.
That site looks manageable, but I hear you on the rain, we keep getting thunderstorms, everyday for a few weeks now, certainly slows things down.[/quote]
Well, so far, to dig the existing part of the pond and pile up the spoils, I have spent about $6000 in fuel. Most of it last summer when I was only paying $2.43/gallon for off road diesel.
I hear what you're saying, but there is no way with owning a 225 am I going to go out and rent a 235 size machine and hire 2 drivers & trucks...
The only problem I'm having right now is the tandem spinning it's wheels. The last thing I need it to destroy the clutch on that truck.
Cheapest thing for me to do is wait on the weather...
At the most, I would rent one articulated truck, and "bang it out" with the equipment I own...
I'm even having issues with my 225, cycle time is very slow due to weak hydraulics. But even still, renting a 235 machine & two trucks with drivers would cost me more than if I continued limping along with what I have. I only need 1 week of dry weather and no machine breakdowns to finish this damn thing.
Thu, Jun 26, 2008 8:14 PM
Catmatt
Send a private message to Catmatt
Reply to ETD66SS:
Considering you have a truck, can you create a haul road with some 4 inch material from a quarry. Even better would be to get some rock out of a stream or dig a hole deep enough to get some rock. That way you could create a haul road, atleast in the areas where there are grades causing slippage of the tires.
Thu, Jun 26, 2008 9:03 PM
Billy D7 4T
Reply to Catmatt:
I hear you, my thinking can be a little agressive having been in and around this kind of work over the years, not the easiest site to work on, add some rain and things get difficult if not impossible.
Those conditions can cause more than clutch problems, running a heavily loaded tandem like that in off road conditions, soft material, hard on the rears and drive train, I had a power divider fail on an off road haul job in soft conditions, the gears blew right through the side of the case like a grenade, still have the pieces. It does not take much, you need a tough truck and a good driver, don't over load it, better to take smaller loads out when in soft conditions.
I think many of us can really appreciate the threads you have posted on this, it really demonstrates what it takes to mass excavate an area, and the problems that can be encountered.
Aside from my aggressive, "contractor" type thinking, in retrospect, I think 1 30 yd articulated dump would still help, though you can really move some material with the right set up, larger excavator, pair of 30 yd dumps going, dozer pushing off, grade the hole as you move out and complete areas as you go, knock out the dam holding back the water at the end. As long as you can load out, you may still move 2x the material vs the tandem, because it can handle double the load and negotiate off road conditions, it's better suited for the job, + it may save your tandem from abuse. My thoughts are always in the direction towards high production and substantial completion, weather and cost escalation really put a damper on this work, drive costs up, but you can only do what the budget allows, hopefully you can see the light at the end of the tunnel by now.
How is that D6 holding up, looks like you have made good use of it so far.
Fri, Jun 27, 2008 10:49 PM
ETD66SS
The D6 has been may favorite machine. I've put probably close to 700 hours on it since I bought it back in 2005. No major problems with it.
I would not be where I am without it...
Fri, Jun 27, 2008 11:25 PM
Billy D7 4T
Reply to ETD66SS:
I forgot what series your is, C or later D, I've ran a lot of those D's, they were reliable, antiquated compared to newer tractors performance by the mid 90's, having run them side by side with new models, both Cat and equivalaent size Komatsu. I was on both a new D65 PX LGP and a new D6 LGP in '94, on the regular shift, we would switch tractors to see which one performed better, when fuel got low on them, I had to get back on one of the 2 D6D's we had on site as well, for the overtime, as the fuel truck only came by in the morning, amazing how much difference there was, felt like you were getting onto an old garden tractor after being on new ones all day, both the D's had new cat U/C's and other work done to them, they still did a lot of work when needed, were well taken care of and went a lot of hours without any major repairs.
Sat, Jun 28, 2008 12:11 PM
Marius Titulescu
Send a private message to Marius Titulescu
Reply to ETD66SS:
[quote="ETD66SS"]The D6 has been may favorite machine. I've put probably close to 700 hours on it since I bought it back in 2005. No major problems with it.
I would not be where I am without it...[/quote]
Totally agree. I've been using it for years with little maintenance. It's a beast.
_______________________________
Marius
Truck fleet
Fri, Oct 7, 2016 3:08 PM
JoeG
Send a private message to JoeG
Reply to Marius Titulescu:
Marius
Truck fleet
When I dug my pond there were several truck used. Off road and others. I had a B-52 Mack here and traction was an issue, we solved it with tire chains. Made the truck much more useful. Mud sticking in the bed was not an issue with the off road truck and we used 315 Cat hoes to load. I'm a couple hours from you, if it weren't Archery season I'd come lend a hand for a day or two. If your still digging after deer season let me know.
Fri, Oct 7, 2016 5:58 PM
old-iron-habit
Reply to JoeG:
I hope he got the pond dug by now. This post is from 2008. I have been known to do that from time to time.
Fri, Oct 7, 2016 8:18 PM
ETD66SS
Reply to JoeG:
Thanks for the offer, but yeah, this is a bit of a resurrected thread 😊
I finished digging in 2011, here's a 2016 Google earth pic: (http://imgur.com/UFrhBHa) Unfortunately had quite the algae bloom when Google took that satellite pic.
The ford L8000 still works, a bit unbelievably... Can't believe the clutch still works.
I've since done a lot more work with the D6C and the UC is just about gone on it now, way past the turning pins & bushing point, but that seems to not be feasible these days anyways.
Sun, Apr 23, 2017 4:56 PM
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
