D8 1-H fan belt
D8 1-H fan belt
mog5858
Can someone tell what the 2 fan belts on a 1-H are. Looking for a gate’s number / belt size and length
Friend just looking to replace. Is there a way to tell by the part number what it is?
Sat, Sep 7, 2019 5:08 AM
posted this recently.
I recall from the past that the Dealer will have a conversion to Manufacturer for vee belts as I used one when I worked there.
Link to past post.
http://www.acmoc.org/bb/showthread.php?32328-17a-fan-belt&p=226002#post226002
Sat, Sep 7, 2019 8:05 AM
Thank you received: 19
Reply to edb:
Link to past post.
I have an ancient Gates Belt specification chart with a numbering system that Gates no longer uses.
Says it's a 3B8904 Cat part number with a Gates number 189T
Says it's a 1-3/8 wide by 63" long x 50 degree side angle.
To be used in matched pairs.
Cat equivalent to the 3B8904 now is a 5L6672
31.8mm (1.25" wide) x 1588mm (62.52" long)
Here's all the interchange numbers if you can believe the source....
http://www.kakapart.com/oem/partscrossinterchange/caterpillar-5l6672.html
Sat, Sep 7, 2019 9:48 AM
Thank you received: 24
Not my question but, you guys with the books and experience need many more thank you's for all you do for everyone that asks questions here. :clap2::clap2::clap2::clap2::clap2::clap2::clap2::clap2::clap2::clap2:
Sun, Sep 8, 2019 12:30 AM
mog5858
Reply to Ray54:
thanks you both for your info. I have saved the V-belt pages for further reference and will pass along the info to my non-computer friend.
Tue, Sep 10, 2019 4:52 AM
Earlcoate Charity Open Day
