D333 engine
D333 engine
Hdonly
Send a private message to Hdonly
Some of you may remember that my 1961 D6B dozer had a cracked block that I have temporarily fixed. It was leaking water out side and some inside into the crankcase. I found this ebay listing for an engine out of a 12E motorgrader listed as a D333 engine block with crank, pistons and camshaft. I have read that this may be a D333 or a D333C engine. I understand that a D333C is not compatible with what I have. If this is a D333, I think his asking price is a little high because he has no idea of the condition. What do you all think? It is close enough that I could go pick it up.
https://www.ebay.com/itm/Caterpillar-D333-Engine-Block-Nohead-12E-Motorgrader-Engine-D6-Engine-Cat-Diesel-/202668775591
[attachment=55131]12E.jpg[/attachment]
Wed, Aug 28, 2019 9:53 PM
Thank you received: 16
7M4400 is a correct casting number for the D333a 4-1/2" bore engine.
Thu, Aug 29, 2019 12:12 AM
Hdonly
Thanks Old Magnet. Want to give an educated guess what the block with crank and pistons would weigh? I have a heavy duty 1/2 ton and a 1 ton truck, but would prefer to use the 1/2 ton if it would handle it.
Just found my engine casting # 4M2950 is this compatible with
7M4400?
Thu, Aug 29, 2019 1:53 AM
Reply to Hdonly:
7M4400?
4M2950 is equivalent to the 7M4400
Complete D333's run about 2000 to 2200 lbs. I'd guess the block and internals is about half of that.
Thu, Aug 29, 2019 2:28 AM
| 34 Henty Hwy, Warracknabeal
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
