RH Helical Drive for 50 MT Starter
Showing 1 to 7 of 7 results
bboaz
Maybe I am not looking in the right places but I am having trouble finding a starter drive for a D-6 9u 6440. I have the motor out rebuilding it and while I had the flywheel housing off I bored the hole for an electric start using the 50MT starter using OM's guide for electric start conversions. This will give me a pony start and also an electric start option. I found the DEH (1951875) on E-bay but cannot seem to find the RH helical drive. Correct me if I am wrong but the teeth on the flywheel go to the left as you look at the flywheel either from the front or back and the teeth on the pony clutch Bendix go to the right. That means I need a RH, counter clockwise drive for the 50MT. The links I have tried on all the conversion threads do not seem to help. Thanks Brian Boaz
Sun, Jul 28, 2019 9:36 PM
You need a RH helical drive (when facing drive end) either 11 or 12 tooth but the sources for the drive appear to have dried up.
Sun, Jul 28, 2019 11:21 PM
restore49
The 42MT positorque (or Spragg?) drive gear can be replaced with a new gear - G2751PT was available last year from VanBergen and Greener in Illinois 800-621-3889 for $21.35.
This was in 2015??? Post #29 Thread 3J D2 Direct Start Question
Mon, Jul 29, 2019 3:10 AM
bboaz
Reply to restore49:
You need a RH helical drive (when facing drive end) either 11 or 12 tooth but the sources for the drive appear to have dried up. You are exactly right Old Magnet, the sources for the drive appear to have dried up. At least now I have another number to try. Thanks
restore49 I will call these folks tomorrow and see what is available. (2015???) If I can get the gear, Maybe I can turn the straight gear off the drive I have and weld the new gear on this drive. If not, it may be time to set the mill up and make an 11 or 12 tooth RH helical gear. This may get real interesting before it gets over. Thanks Brian Boaz
Mon, Jul 29, 2019 7:50 AM
big harold
Send a private message to big harold
Reply to bboaz:
Send an email to George. George Scott
Or give him a ring - If you have any other questions, feel free call the shop at 903-892-8551 Mon - Fri, 8AM - 3PM CDT.
Helped me out with Starter nose and Helix.
Good to deal with even from the land down under.
Mark
Mon, Jul 29, 2019 9:56 AM
big harold
Reply to big harold:
Mark
Or another
Ted Turner
C. C. Battery Co., Inc.
361-882-5561, 800-531-1038
ccbattery
Mark
Mon, Jul 29, 2019 9:58 AM
restore49
Or another
Ted Turner
ccbattery
Mark
Bboaz:
The gear itself is replaceable - comes off your Positorque Bendix. No machining required.
Mon, Jul 29, 2019 6:44 PM
bboaz
Reply to restore49:
Bboaz:
Found the drive Locally
J & I Automotive Distributors, in Marshfield Mo.
417-468-2439
$70.00
[attachment=54867]Resized_20190729_111645.jpg[/attachment] [attachment=54868]20190729_111626.jpg[/attachment]
They also carry the DEH that goes with the drive for the conversion. The box the drive came in was marked J & N which is a supplier. The folks at J&I said he normally keeps one drive in stock but can get them in a couple of days.
Tue, Jul 30, 2019 1:06 AM
| Hartley - South Australia
Newby Hall Tractor Fest
