Engine block of the 955l small crack . HELP
uisum
Send a private message to uisum
Hello people.
I discovered that the 955l engine block has a slight crack behind the starter motor.
Light drops of water come out cold. When it is hot, nothing comes out. How can I repair it? What material is it?
I was thinking of filing and inserting liquid metal or making them a weld bead. Do you confirm cast iron?
I also discovered a slight crack in the oil sump, what material is it?
Thank you all.
Sat, Jul 13, 2019 1:34 AM
vansgarage
Send a private message to vansgarage
I have had experience with cracks on 1926 ALF fire truck engine cylinder jugs, in an area near a valve seat, and water jackets. It was stitch weld repaired, a very good but tedious job. No heat, or trying to weld old impurer metal castings. I have also used J B Weld, which is a 2 part epoxy mix on the same castings with success. I had a crack in the oil pan on a D-2, preheating and welding never worked. Good luck, I hate cracks in cast iron.
Sat, Jul 13, 2019 2:31 AM
oldbeek
Reply to vansgarage:
Dyke stop leak for minor leaks.
Sat, Jul 13, 2019 2:42 AM
Thank you received: 40
Reply to oldbeek:
Hi, uisum.
This thread may be helpful:
http://www.acmoc.org/bb/showthread.php?32308-O-T-But-Could-Be-Useful
Sat, Jul 13, 2019 5:11 AM
