Adjust the steering clutches and brakes of the cat 955l.
Showing 1 to 10 of 10 results
uisum
Send a private message to uisum
Hello people.
How to adjust, the steering clutches and brakes of the cat 955l . If someone has the scheme or procedure, it would be great.
Thank you
Fri, Jul 5, 2019 11:31 AM
rover
Send a private message to rover
Hi Uisum
At the back of machine under the fuel tank unbolt that panel,and on top of the final drive housing there are two alloy upside down covers.I think three 9/16 af bolts in each,
one on the left and one on the right of the final drive.Under these you will see a threaded bar with lock nut just screw up or down to loosen or tighten steering pedals.
Keep checking height of pedals and do not over tighten or it will not release clutch first.It been 30 years since ive done one,but nothing changes on old cats
regards glen
Fri, Jul 5, 2019 3:37 PM
uisum
Reply to rover:
Hi Uisum
regards glen
[quote="rover"]Hi Uisum
regards glen[/quote]
Ok thanks you
Fri, Jul 5, 2019 5:16 PM
cg3p0
Send a private message to cg3p0
Reply to uisum:
Ok thanks you
I just went through my pedals the other day, and i filmed it. There is another adjustment point for the clutches if you dig further into the machine, but i would just start with the linkages and that should do.
[video]https://youtu.be/N-c6zLW_AWg[/video]
Fri, Jul 5, 2019 6:49 PM
uisum
Reply to cg3p0:
[quote="cg3p0"]I just went through my pedals the other day, and i filmed it. There is another adjustment point for the clutches if you dig further into the machine, but i would just start with the linkages and that should do.
[video]https://youtu.be/N-c6zLW_AWg[/video][/quote]
wow, I love this kind of video.
thanks friend
keep it up...
Fri, Jul 5, 2019 7:41 PM
cg3p0
Reply to uisum:
thanks friend
keep it up...
Prego! Buona fortuna!
Fri, Jul 5, 2019 10:09 PM
uisum
Reply to cg3p0:
Hello. do you have a pdf manual?
You know the safety lever that allows you to enter the gears (accelerator side), the lever goes down by itself. Perhaps there is a spring that holds the mechanism?
Without pattern I can't understand.
thank you
Sat, Jul 6, 2019 5:30 PM
cg3p0
Reply to uisum:
thank you
This is the only picture i could find of it. Hope that helps.
[attachment=54625]italia.jpg[/attachment]
Sat, Jul 6, 2019 7:48 PM
Reply to cg3p0:
There is allot more to adjust than just the linkage rods, there is the yolk arm links and the roller arm linkages for the clutch booster. The clearances vary according to serial numbers.
Sat, Jul 6, 2019 8:57 PM
cg3p0
The rollers are adjusted with the rod linkage adjustments (green). The yolk linkage adjustments, at least on my machine, require the gas tank to be lifted (red). There are two plates on top the steering booster cover in the back that reveal the adjustment point.
This manual covers serial number:
57J1-up
64J1-9257
71J1-5831
85J1-10128
[attachment=54626]adjustments.jpg[/attachment]
Sat, Jul 6, 2019 11:15 PM
uisum
Reply to cg3p0:
57J1-up
64J1-9257
71J1-5831
85J1-10128
[quote="cg3p0"]The rollers are adjusted with the rod linkage adjustments (green). The yolk linkage adjustments, at least on my machine, require the gas tank to be lifted (red). There are two plates on top the steering booster cover in the back that reveal the adjustment point.
57J1-up
64J1-9257
71J1-5831
85J1-10128
[/quote]
hello friend thanks a lot.
I solved.
If I need to, I'll let you know.
Mon, Jul 8, 2019 2:58 AM
| Hartley - South Australia
Newby Hall Tractor Fest
