Points voltage regulator to electronic Conversion??
1941D4DOZERBOY
Send a private message to 1941D4DOZERBOY
I have a D4 dozer and 9T grader, I had the generators rebuilt and now would like to upgrade to electronic voltage regulator. Anyone done this before?? part numbers for parts and wiring diagrams would be appreciated!!
Sun, Jun 16, 2019 6:13 AM
Thank you received: 21
Yes, I made this upgrade to my 5U D2 a couple of years ago. I'm using the original 6v generator with a Optima 6v AGM battery and the regulator is a Clover Systems DR110, which bolts on to the same location as the original regulator and has the same connections. It works perfectly - the generator easily keeps the battery charged even though it only runs a couple of times per year.
Look it up online at cloversystems.com
Sun, Jun 16, 2019 6:20 AM
1941D4DOZERBOY
looks like that website is closed. im looking for a 12 volt solid state electronic voltage regulator for the generators on these tractors. im tired of cleaning the points on them. anyone out there done this??
Sun, Jun 16, 2019 11:26 PM
Reply to 1941D4DOZERBOY:
Try this email and see if it gets through. I contacted Gordon this time last year for some info
They were also offering 12v regulators
Mon, Jun 17, 2019 12:52 AM
rhartwick
Send a private message to rhartwick
I put one on our AC D17 tractor after several junk aftermarket regulators. No problems and it works with no problems. Yo u have to specify the generator model and it's polarity. I switched the 17 to negative ground. The electronic regulator worked fine.
Mon, Jun 17, 2019 6:54 AM
