3406 starter on a D330A
Showing 1 to 9 of 9 results
PhilC
Hello All
Does anyone know if a 3406 starter would fit on a D330A engine? This is the one. The starter looks a lot different but I was hoping the mount would be the same.
Regards
Phil
Sun, Jun 9, 2019 3:19 PM
I don't believe there is anything unique about the 3406 starter but the D330A will require a 1M0023 adapter.
What model starter is on the 3406?
Sun, Jun 9, 2019 10:12 PM
PhilC
Hello OM
I have asked the seller for more details.
That adapter is $350 from Cat. There is already an adapter on the old starter, I will see if it is the 1M0023.
Regards
Phil
Mon, Jun 10, 2019 7:08 PM
I think that starter is the mirror image of the one you need. The starters on those machines are mounted on the left side of the engine as it sits in the loader with the fan toward the back.
That appears to be a DENSO? for a much smaller engine, but maybe it is a planetary gear reduction type and will do the job. Still, it would mount on the right side of the flywheel as the engine sits in the loader. Maybe the drive end housing can be unbolted and clocked for the opposite side.
The going rate for a new import Delco 42MT knock-off is about $240 US. Anything else is going to have to be CHEAP. I pulled the one from probably 1989 off my tractor the other day and discovered it had a thin adapter ring to mount in the bell housing of the 855 Cummins. Thats a first for me, I never saw an adapter used except on the old Caterpillars that have the big hole for the buzz bomb ponies. I was able to get it going and reinstall it, so I didnt have to investigate the actual configuration I had to buy another one.
Mon, Jun 10, 2019 9:57 PM
Are others seeing an image of the starter? If so, it's no showing up on my computer????
Mon, Jun 10, 2019 10:07 PM
gary in CA
https://www.gumtree.com.au/s-ad/garbutt/truck-parts/cat-3406-c15-c18-24-volt-starter-motor/1215769116
Mon, Jun 10, 2019 10:15 PM
OK, now I see it, thanks Gary in Ca.
Complications...
Can't tell for sure if that drive end housing is indexible.
Is the 330A originally pony start or direct electric start? (bevel gear flywheel teeth or straight tooth)
If a bevel gear starter drive is required they are only are available for the 40,42,50 MT starters.
Mon, Jun 10, 2019 10:39 PM
keloz
Send a private message to keloz
Complications...
Hi OM how are you i have one off those starters off of a 855 i should see if the bevel pinion will fit because would give you a lot more room they are a lot smaller than the delco s planety as cj says mine come off a kenworth i put air starter on its 24 v too
Tue, Jun 11, 2019 6:43 AM
Reply to keloz:
That would be good to know, might just work seeing it has the drive end housing with the outer bearing support but I have my doubts. Certainly doesn't work with gear reduction starters with the over hanging pinion (no outer support).
The Denso starter may be more compact but it's pretty hard to beat the durability and performance of the 40, 42, 50 MT series.
Tue, Jun 11, 2019 10:46 AM
PhilC
[quote="ccjersey"]
That appears to be a DENSO? [/quote]
Thanks ccjersey
That is enough for me to look elsewhere. Had nothing but trouble with Denso starters. OM is right Delco starters are hard to beat.
Thanks also for that info. I could not work out why Cat put an adapter flange on the starter. Now I know😊
Regards
Phil
Tue, Jun 11, 2019 3:42 PM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
