Cat 951c adjust the valves.
Showing 1 to 10 of 33 results
uisum
Send a private message to uisum
Hi everyone.
I installed a new head on my charger.
I have to adjust the valves.
I inserted the bolt in the flywheel, and the pistons 1 and 4 are completely up, flush with the block.
I recorded these 2 pistons, valves completely closed and with the thickness gauge I measured the clearance of 0.68 exhaust and 0.38 inlet.
How can I adjust the central pistons 3, 4?
THANK YOU
Fri, May 31, 2019 1:49 AM
Valve adjustment.....
4-cyl, 1,3,4,2 firing order
Position #1 @ TDC
Adj. Intake #1 & 2, Exh #1 & 3
Rotate 360 deg. to #4 @ TDC
Adj Intake #4 & 3, Exh #4 & 2
Intake adjustment 0.015"
Exhaust adjustment 0.025"
Adjustments made with cold engine.
Fri, May 31, 2019 2:12 AM
uisum
Position #1 @ TDC
[quote="Old Magnet"]Valve adjustment.....
Position #1 @ TDC
Adjustments made with cold engine.[/quote]
hello I thank you.
I didn't understand.
on the flywheel I removed the cap 4h6112, I inserted the bolt.
Pistons 1 and 4 have risen to the top. the central pistons went down.
I reassembled the used head and the valves. In the piston 1 the valves were crushed, I unscrewed and brought them closed ... I did the same with the last piston.
I don't understand anything ... I'm doing old magnet wrong?
I'm afraid of making trouble
Fri, May 31, 2019 2:53 AM
Reply to uisum:
Position #1 @ TDC
hello I thank you.
You have to follow the adjustment sequence. You can't adjust piston 1 and 4 at the same time.
Make sure you are at #1 piston top dead center not #4.
Installing the bolt at #1 TDC is where you start the adjustments.
When the #1 TDC position valve adjustments are done, rotate the crankshaft one full turn to where you could insert the bolt with #4 at TDC.
Complete the adjustments for the #4 TDC position and you are done.
If you don't understand get some help from someone who knows engines.
Don't guess if you don't know as severe engine damage can occur if you get it wrong.
Fri, May 31, 2019 3:26 AM
uisum
Ok I'll try.
When I set the valves in the order you told me, they must be completely closed, right?
ps. piston dead center 1, and when it's completely up, right?
Piston 1 is the one near the flywheel, right?
I'll let you know tomorrow.
THANK YOU
Fri, May 31, 2019 3:52 AM
uisum
Reply to uisum:
Ok I'll try.
THANK YOU
[attachment=54162]IMG_20190530_232306.jpg[/attachment]
Is this the order of the pistons?
piston 1 opposite the flywheel
Fri, May 31, 2019 4:31 AM
Reply to uisum:
Evviva!!! you got it!
Fri, May 31, 2019 5:02 AM
Yes, valve should be closed for adjustment.
#1 is at the front of the engine.
To check when done put #1 piston at TDC again. Both intake and exhaust should be closed.
Fri, May 31, 2019 5:24 AM
uisum
[quote="Old Magnet"]Yes, valve should be closed for adjustment.
To check when done put #1 piston at TDC again. Both intake and exhaust should be closed.[/quote]
Hello .
I set the valves in the correct order. They were almost already ok.
I made minor corrections.
I reassembled everything else except the exhaust manifold.
I discovered that piston 1 does a lot of gray smoke, all the others don't smoke almost anything.
I practically didn't solve the problem.
The engine sounds exactly like before.
What could I check?
The Valves are new.
If I accelerate suddenly it almost drowns and makes a lot of smoke.
Maybe you remember the videos I put on.
Thanks you
Fri, May 31, 2019 6:15 PM
Have any of the pump units been removed and replaced in the injection pump?
It's quite easy to reinstall them out of time with the rack. This results in strange sounds and lots of black smoke. If the manifold is installed already, the test for which one is wrong is to loosen each injection pipe connection in turn until the strange noise and smoke stops.
Fri, May 31, 2019 7:48 PM
No pump quadrants and rack involved here, this unit has sleeve metering injection. I hope the sleeve adjustments haven't been messed with as it take some special equipment to time these units.
Fri, May 31, 2019 10:27 PM
Newby Hall Tractor Fest
