Login | Register
Cat 212
Showing 1 to 10 of 11 results
bigkit
Send a private message to bigkit
Hi, I've been restoring this lovely grader with my son. We would like to find a scarifyer if anyone has one please. Any help would be most appreciated. Thank you
[attachment=54156]IMG_3011.JPG[/attachment]
Thu, May 30, 2019 4:01 AM
Pretty slick with that dozer blade attachment. Great father/son project and good job!!!!
Thu, May 30, 2019 11:14 PM
bigkit
Many thanks. It's been a long road, nearly there. I'd just like the scarifyer to make it complete. The previous owner made a lovely job of a power steering conversion which helps immensely.
Fri, May 31, 2019 12:45 PM
How would the scarifier be controlled? I am thinking there was a splitter gearbox on the circle rotate that was used for the one I had once. What is used to operate the dozer? It may be simple......it's been a long time since I looked at one.
I"ll second the vote for nice job on that project! What was the source of the machine? Contractor, government?
Fri, May 31, 2019 6:51 PM
bigkit
hi, thanks all for your kind words. The scarifyer is controlled from a change over lever in the cab that swaps between the scarifyer and wheel lean. There should be a gearbox to
operate it mounted on the brackets on top of the frame near the front.
The machine was originally a Swedish army one which later went into the Swedish highways. I bought it in Sweden and brought it home.
Fri, May 31, 2019 7:04 PM
Reply to bigkit:
Hi, Bigkit.
P. D. S.. Pretty Darned Slick. Thanks for sharing. Hope you find that scarifier soon.
Just my 0.02
Sat, Jun 1, 2019 2:38 PM
D4Jim
Hi, Bigkit.
Just my 0.02
Great job on the old grader.
Hope you find the scarifier to complete the project. They should have named them "scarceifiers" as they are so scarce and hard to find. Good luck!!
Sun, Jun 2, 2019 12:04 AM
jumbo
Send a private message to jumbo
Reply to D4Jim:
Interesting steps to get into the grader, I have not seen steps like that. Also, it appears your front tires and rear tires are the same size, am I mistaken?
I'm not afraid of hard work; I can lay down beside it anytime and take a nap.
Sun, Jun 2, 2019 1:09 AM
STEPHEN
Reply to jumbo:
24" rubber on the front was an option, but one that seems less appealing now that proper tires are so scarce.
Sun, Jun 2, 2019 2:52 AM
bigkit
Reply to STEPHEN:
Hi, thanks for the feedback. Yes the fronts are 24's, I like the look. You can get them but only in chevron pattern that I've found so far. I took of the worn rear ones to save for the front then put new matching rears on.
Sun, Jun 2, 2019 2:18 PM
catskinner
Reply to bigkit:
Hello,
Do a search for Weller Tractor Salvage in Great Bend, KS. They salvage graders and may have what you are looking for. catskinner
Sat, Jun 8, 2019 10:05 AM
Booleroo 2025
CAFES 2025 TULARE, CALIFORNIA
| Tulare, California
| 34 Henty Hwy, Warracknabeal
