trojan 124 off topic
Showing 1 to 10 of 17 results
Hobo groh
Send a private message to Hobo groh
hello my niebor has a trojan pay loader he said the transmisson hose broke he wants 1500$ is this a good price being that the parts i could find were none
Mon, Apr 29, 2019 2:40 AM
Thank you received: 35
Hi, Hobo groh.
I yain't sure but I think the Trojan brand quite producing machines back in the 1960s or '70s. As I understand it, they were not an original manufacturer, except for the machine frames. I think most of the mechanicals were from companies like GM/Detroit Diesel, Cummins, Allison and/or Clark for transmissions and differentials, etc., etc.. If so, then many of these parts may well still be around but frame parts could be made of extremely high-grade 'unobtainium'.
Also, it might be worth checking the availability of replacement 'tahrs' for that particular size/model of machine.
Mon, Apr 29, 2019 3:24 AM
Hobo groh
Hi, Hobo groh.
Okay I will look thank you
Mon, Apr 29, 2019 6:51 AM
oldbeek
Reply to Hobo groh:
The nicest thing I can say about a Trojan 124 is it is a piece of junk. Built to weak for its size. 4 ea 1300x 24 tires $2200.00 plus installation. Had 5 in the 70s in a fleet where I worked. continually breaking. Couldn't afford to keep fixing them. Replaced with Cat 120s that required no repair at all in the same service environment.
Mon, Apr 29, 2019 10:58 AM
Hobo groh
Reply to oldbeek:
It also has a Perkins diesel and do you know a place to find transmission parts.
Mon, Apr 29, 2019 11:17 PM
kracked1
Reply to Hobo groh:
What kind of transmission? Should be a tag or name plate on it some place.
Tue, Apr 30, 2019 2:12 AM
Hobo groh
Reply to kracked1:
Didn’t see one all I know it is a124 that also has a Clark serial tag on it
Tue, Apr 30, 2019 3:28 AM
Hobo groh
Reply to Hobo groh:
Looks like this copy and paste this link
https://www.truck1.eu/construction-machinery/wheel-loaders/trojan-124-a1529628.html
Tue, Apr 30, 2019 3:58 AM
oldbeek
Reply to Hobo groh:
The transmissions were the weakest link. Probably a clark but don't quote me. The shafts were soft and would erode away. The disks would not handle the fwd and reverse action while loading trucks. Trans repair would get very expensive. Typical repair cost on a trojan for the first 4,000 hrs would be $40,000. First 4,000 hrs on a CAT 120 was $2,000 for oil and filter service. Keep in mind back in those days the machine only cost $35,000. Stupid county controllers never could understand that low bid was not the most cost effective over the life cycle.
Tue, Apr 30, 2019 1:06 PM
Hobo groh
Reply to oldbeek:
so i guesing when the seller said it sprayed transmission oil sprayed all over it proply was a gasket or something big went wrong
Sat, May 4, 2019 1:21 AM
bursitis
Reply to Hobo groh:
could just be a hose. i agree it is probably a clark transmission. i hope it is cheap.
Sat, May 4, 2019 4:36 AM
