Looking for brass fuel line fittings for a 22
Mike Meyer
I need to replace the fuel lines and fuel tank taps on my 22, has someone already gone down this path and found a modern supplier of the various parts including
3640-A "Valve" (fuel tap)
L-1547 Nut
L-1548 Sleeve
3273-A Elbow
2837-A Clip
I'll also be doing the oil gauge line so if you have a source for the nipples and nuts there too I'd appreciate it
Could you also confirm the copper pipe size used for both the fuel line and the oil pipe, here in Oz everything is metric so hopefully that doesn't screw me up too much.
Mike
Fri, Apr 12, 2019 3:20 AM
Mike Meyer
I think I found some good numbers
3640-A Valve might become 5M4639
L-1547 Nut might become 3H1829
L-1548 Sleeve might become 3H1830
Fri, Apr 12, 2019 5:45 AM
brewzer
Reply to Mike Meyer:
I have used ones if you cannot find new.
Wally
Fri, Apr 12, 2019 10:08 AM
Mike Meyer
Reply to brewzer:
Wally
Thanks Wally, I'll keep it in mind, I'll be in the Salinas Valley in June.
Mike
Sat, Apr 13, 2019 8:05 AM
Lance Jones
Mike
Mike, have You Checked these Numbers for Price and Availability, Someone told Me Tilly's have or had Sleeves LJ
Mon, Apr 15, 2019 2:06 AM
Mike Meyer
Reply to Lance Jones:
Morning Lance, I had forgotten about Tilly's, thanks for reminding me.
Did you get the brass taps back safely in the mail?
Regards
Mike
Mon, Apr 15, 2019 3:39 AM
| Hartley - South Australia
Newby Hall Tractor Fest
