<span style="font-family:Arial">Gentleman, I’m a ACMOC Member who has been shopping for a clean D4 6U (Narrow Gauge) for over a year now. Today I inspected a very sweet 1953 model, S/N 6U8430. Below are the details of my inspection.
Please tell me what a fair price would be for a California Narrow Gauge D4!</span>
<span style="font-family:Arial"> </span>
<span style="font-family:Arial">1953 Narrow (44” wide gauge)
</span>
<span style="font-family:Arial">Cat 44 Hydraulics with Nose Guard.</span>
<span style="font-family:Arial">Original CAT Single Spool Hydraulic Valve with an owner added selector valve to operate either the Blade or the Rippers one-at-a-time.
</span>
<span style="font-family:Arial">Cat 4S Straight Blade, very clean and straight except for one small dent in its center area. Blade Pivot Points seem to not be too sloppy. </span>
<span style="font-family:Arial">Unknown make of two ram hydraulic Ripper Bar with 3 of 5 shanks installed. (Replaces the Cat Drawbar due to its installation) The Ripper Frame also covered the rear Serial Number Plate from view.</span>
<span style="font-family:Arial">Has both lower engine side guards with some small “tears”. The Hood is straight but not a Cat Brand Hood. (Needs a replacement: How much $???)
</span>
<span style="font-family:Arial">Home-made ROPS bolted to the fenders. (Its gotta go.
)</span>
<span style="font-family:Arial">Has the “heavy” (ribbed) Rock Guards over the lower (four) Rollers.
</span>
<span style="font-family:Arial">Undercarriage Specs:</span>
- <span style="font-family:Arial">Pins and Bushings have NOT been turned. Rear Sprockets look real good with flat areas on the “points”. </span>
- <span style="font-family:Arial">The 5 Rail Link measurement is 27.25” which I calculate to be 41% wear - 59% remaining. </span>
- <span style="font-family:Arial">The Rail Height is at 3.5781” or about 34% wear - 66% remaining. </span>
- <span style="font-family:Arial">The Grousers are the worst as they have had bars welded on them but the Grouser pads are worn where the overlap with the next pad. (What’s the current cost of new Narrow Gauge Grouser Pads for both sides???) </span>
- <span style="font-family:Arial">FYI: The distance from the Front Idler Axle center to the front of the Track Rail is 6.25”.</span>
<span style="font-family:Arial">Both Motor’s:
</span>
<span style="font-family:Arial">The Electric Start Pony starts well and runs smooth once choked properly.</span>
<span style="font-family:Arial">The main engine oil pressure comes up quickly while the Pony is turning over the main before it has been started. Then the Oil Pressure is even higher with the diesel engine running at idle.</span>
<span style="font-family:Arial">The Diesel engine starts up easily with only some initial start-up smoke then literally purrs at idle. During the entire demo the engine never smoked or spewed oily spots, it ran so smooth and sounded very sweet. (It has a rain flapper and a muffler.)</span>
<span style="font-family:Arial">The Clutches and Brakes responded to all inputs and all gears worked well – forward and reverse. </span>
<span style="font-family:Arial"> The owner has had it 2 years to build 2 house pads but never changed the oil. The Radiator water is clear with signs of having 50% Glycol added.</span>
<span style="font-family:Arial">The fan belt seems a little loose.</span>
<span style="font-family:Arial">There are no lights:( </span>
<span style="font-family:Arial">Paint (saw two layers in some places) and Seat Covers are good with the side seat pads being present.</span>
<span style="font-family:Arial">One 1.5” wide dent in the back of the Seat Tank Metal. Both Fenders are straight; however both have bolt holes added for the homemade ROPS.</span>
<span style="font-family:Arial">Decals are present but some are wrong like on the Hood Sides.</span>
<span style="font-family:Arial">All Hydraulic Cylinders are leak free and the chrome is very good.</span>
<span style="font-family:Arial">There is some dried oil/dust staining on the bottom side of the Hydraulic Pump/Reservoir Guard.</span>
<span style="font-family:Arial">Minimal small rust spots as one would expect in California. The Paint is generally good.</span>
<span style="font-family:Arial">SO…….
What is this Cat worth??? </span>
<span style="font-family:Arial">P.S. It will cost me about $750 bucks to have it moveed the 44 miles to my house. (Diesel out here is over $5.00 a gallon now!!!)</span>
The main negative not to buy this Cat is that this D4 is too heavy for my new 14K Tilt Bed Trailer!! I figure the Dozer with the rippers and ROPS is about 14,000 pounds, so I couldn't take to ACMOC shows like the BSOT!!! Maybe I should start looking for a nice late model D2!!!
