3306 turbo on d333t in d6c 76a prefix
Showing 1 to 10 of 12 results
D6c76a
Send a private message to D6c76a
Hey guys ,I got the tractor in to work on ,found oil in intake side and lots of play in turbo shaft.. The exhaust side of tbe turbo flange is falling apart from rust and heat..
3306 turbos are cheap and plentiful, would one from a d6d work? I have my pump out for rebuilding and to be set at 140hp. Fab work is no problem to connect intake and exhaust..
What say Ye.
Tue, Mar 26, 2019 8:04 PM
Casey Root
This sounds interesting. If you do make the switch, please show us how it's done. (photos)
I installed a rebuilt turbo on my 74A couple of years ago and at that time it was $1,000. Did not put the screws to the pump. Still stock.
Tue, Mar 26, 2019 8:46 PM
D6c76a
Reply to Casey Root:
Ya the exhaust side of the turbo cartridge v band flange is rusted away. It would need a remain.
I see reman ones for the d6d around $4-600.
Tue, Mar 26, 2019 9:48 PM
EL300B
Send a private message to EL300B
Reply to D6c76a:
Had a 17A D-7 that the turbo went bad and could not find a new cartridge for it.Found a used turbo from a D-6C and put it on.Bolted right on and seemed to work well.I would think a turbo from a 3306 should work fine on a d333.
Tue, Mar 26, 2019 10:31 PM
Reply to EL300B:
The 9S9243 field replacement turbo is still a good number and runs about $1000.
Wed, Mar 27, 2019 1:59 AM
Tad Wicks
Careful what you do, without a waste gate you might just beat the wrist pin bushings out of it or something worse. Locals here ran the boost up on a TD25 and did that very thing.
Wed, Mar 27, 2019 7:33 AM
D6c76a
Reply to Tad Wicks:
Old magnet do you think the 0r-5812 would be a suitable replacement. Cat dealer pulled this up as interchangeable to d6c with 3306.
This can be had for $500 ish aftermarket.
Wed, Mar 27, 2019 7:21 PM
Reply to D6c76a:
I don't have information to verify the interchange. There is a difference in cubic inch displacement but that may not be significant. The flange mounting dimensions would need to be checked. Perhaps a phone call to Garret Turbochargers would get the answers.
Wed, Mar 27, 2019 11:29 PM
D6c76a
Ok guys,im posting this for future reference for people with the older big low speed turbo needing a replacement.
I dug around and between my research and cat,decided to take a gamble on a new turbo part # 0R-5812. This is the turbo on the 10k series d6c with d333c and 3306. I'm happy to report it paid off,it is a direct bolt on for the earlier d333t engine.
I didn't have to change anything, all intake, exhaust, and oil lines fit like it came with it originally. Cat wanted $1800,found a new aftermarket for $525 inc shipping.
I've got my precups resealed, new injectors in,new glowplugs, new exhaust manifold, and new turbo. Waiting on guy to finish up the injection,and transfer pumps.
I can't wait to bust her off again
Sat, Apr 13, 2019 7:09 PM
Reply to D6c76a:
Thanks for getting back to us, duly noted and filed.
Sat, Apr 13, 2019 9:58 PM
Casey Root
Thank You very much. Your efforts are much appreciated. The part number and description is now referenced on the inside front cover of my parts book.
There was a difference of 20 hp between models. Are you setting the new pump for the higher hp?
Thanks again.
Sun, Apr 14, 2019 12:43 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
