cat 14e motor grader
16 years 5 months ago #17402 by dover
cat 14e motor grader was created by dover
Hello,
I just bought a 14e motor grader to take care of the road to the new house. It came with a service manual that lists the vin# of c35f-1028. I was just wondering if anyone had any good info on year(was told mid 60's), or anything else I should know. Pics Attached.
Thank you,
Ben
16 years 5 months ago #17409 by SJ
Replied by SJ on topic !4C Grader
The Cat book says they came out in 1959 so it could be a 1960 grader as my book only has start up dates but some on here has books with the exact date of manuf.They are listed as a 14C and not an E series. The book says the 14D came out in 1961.
16 years 5 months ago #17412 by Old Magnet
Replied by Old Magnet on topic cat 14e motor grader
14C - 35F1028 is a 1960 model.
16 years 5 months ago #17414 by dover
Replied by dover on topic cat 14e motor grader
There is another vin that is something91something. I'm at work and dont have the books so I can't tell for sure. The book lists it as an E so that might not be the right vin or wrong book? Where should I look on the machine to see if the vin tag is still there? It runs well and has a V plow also and form my digging the $5,000 I paid looked like a good deal, any imput on that?
Ben
16 years 5 months ago #17415 by SJ
Replied by SJ on topic SN
The serial number should be on the left rear of the block just below the head so look there.I can,t remember if or where a 2nd SN plate is on them but maybe someone else can help there.The 3 14E SNs are 72G & 99G & 12K so you need to check the serial number before we guess any more on it. The 14C grader is a 35F serial number so look for a 35F on the SN plate or any other number.
16 years 5 months ago #17417 by Old Magnet
Should be another tag forward on the LH frame rail just behind and above the front wheel.
16 years 5 months ago #17433 by dover
The parts book lists serial numbers of 96f1. I will look at the machine on Thursday, but I doubt the tag on the front will still be there.
Thank you,
Ben
16 years 5 months ago #17438 by Old Magnet
The 96F1-up series is a Model 14D (1962-1965)
16 years 5 months ago #17443 by Eds-oldiron
Replied by Eds-oldiron on topic cat 14e motor grader
Dover..I bought a 96F 14D in 1999 for 4 thousand, had a bad axle, support, bearings, etc, etc,. Spent 2 thousand getting it fixed. Stong machine, it would easily push a moldboard full of dirt. I used it for over four years and sold it for 10 thousand, I think you did all right, if everything works.
The 14D 96F has a 4sp trans with a forward and reverse lever. The 14E 99G has hydraulic over mechanical controls. A couple of ways to tell them apart.
16 years 5 months ago #17457 by dover
Mine is straight nuckle buster controls so it must be a C or D. Everything appears to works other than the brakes, blade slide, and blade roll. I didn't think 5 grand was a bad price before I found out it had a Vplow and extra set of brand new edges.
Ben
Time to create page: 0.167 seconds
