Cat 33 pull behind grader
Showing 1 to 10 of 11 results
GMFkenya
Send a private message to GMFkenya
Hi All,
I run a nature conservancy in Kenya and we are trying to refurbish an ancient CAT 33 pull behind grader. It is an ancient machine that has been used on the conservancy for decades. We are bringing it back to life as we have 500km of roads to grade on a tight budget but are having difficulty working out the front wheel angling connections since they were damaged and must have been removed at some point. I’m trying to reach out to anyone who might have the designs, parts or any knowledge on how the connection through the central column attaches to the gearbox on the front axle.
Many thanks,
[attachment=53008]image002.jpg[/attachment][attachment=53009]image001.jpg[/attachment][attachment=53010]ec9dffba-b559-4325-a4cc-d56e0fe57e1d.jpg[/attachment]
Fri, Mar 8, 2019 3:42 PM
Online
Thank you received: 12
Hi, GMFkenya.
Welcome to the forum. 500 miles of roads to grade with that Number 33, that's quite a project. Just keep at it and you'll get there.
I am attaching a photo of a Cat Sixty leaning wheel grader brochure which may not be exactly the same but would be similar. You can see a part of the lean wheel gear rack on the lean wheel crossbar behind the axle and in front of the scarifier. Sadly, it is the only photo I have. Hope it helps.
[attachment=53011]Cat 60 leaning wheel grader brochure 1929-31_1L_Acmoc.jpg[/attachment]
Fri, Mar 8, 2019 9:13 PM
seiscat
Hi, GMFkenya.
About 311 miles Deas, lol. Still a bunch to grade with anything but especially with a 33.
Craig
Fri, Mar 8, 2019 11:21 PM
Online
Reply to seiscat:
Craig
Hi, seiscat.
I musta bin inna hurry and missed the 'klms' bit. Thanks for the heads-up.
I suspect that using a small cat terracer behind a crawler might be worse. LOL.
Fri, Mar 8, 2019 11:32 PM
chriscokid
Reply to seiscat:
Craig
i sent you an email with pics of parts book showing detailed pics.
Fri, Mar 8, 2019 11:40 PM
GMFkenya
Hi, GMFkenya.
[quote="Deas Plant."]Hi, GMFkenya.
Just my 0.02.[/quote]
Thanks Deas. Its a great picture but I need the technical details. I was hoping someone might have one they could get right into and take some pics.
Sat, Mar 9, 2019 12:36 AM
Online
Reply to chriscokid:
Hi, chriscokid.
Thanks for jumping in here. I thought you might be the go-to person for this one.
Sat, Mar 9, 2019 12:37 AM
GMFkenya
Thanks Erik, really useful. I'll send them on to the engineers. You don't happen to know anyone who has one? Some close up pics would also be of help.
HOLLANDCAT
Send a private message to HOLLANDCAT
Reply to GMFkenya:
GMFkenia,
I will make pictures tomorrow from my No33 and put these on here.
Gilbert
Sat, Mar 9, 2019 6:05 AM
GMFkenya
Reply to HOLLANDCAT:
GMFkenia,
Gilbert
[attachment=53024]Grader front axle .jpg[/attachment][attachment=53024]Grader front axle .jpg[/attachment][quote="HOLLANDCAT"]GMFkenia,
Gilbert[/quote]
Hi Gilbert, that would be awesome. The real issue is the connection through the central column on the front axle to the gearbox. There seems to be a shaft that goes from the connecting rod at the top through the main ball and socket joint, possibly attaches to another 2 shafts and then into the gear box. This controls the angling of the front wheels. If you can get close up pics of how this all connects and possibly the dimensions of the connecting parts, as I think we might have to manufacture since I cannot find another one in Kenya, it would be a huge help.
Thanks so much,
N
Sat, Mar 9, 2019 5:45 PM
GMFkenya
[quote="GMFkenya"]Hi All,
Many thanks,
[/quote]
So Erik just confirmed its actually a 44 not a 33 from the serial number. Many thanks for sorting that one out!
Sun, Mar 10, 2019 12:09 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
