D2-5U pony tank valve
Showing 1 to 9 of 9 results
beaver-flat
Send a private message to beaver-flat
I think the shutoff valve for the pony tank on my D2-5U is leaking internally.
It's a 1/4 turn brass valve, anybody know if these are still available?
Wed, Feb 20, 2019 8:01 AM
STEPHEN
Not familiar with that style on the 5U unless it is an early unit? You might find one of the more common valve/filter units.
Wed, Feb 20, 2019 8:41 AM
Reply to STEPHEN:
on later U and other machines with ponies Cat fitted an extra tap to overcome flooding the pony with petrol/gas when shut off.
The un-initiated often forget the second tap and curse ponies for being cantankerous.
Keep Smiling,
Wed, Feb 20, 2019 9:42 AM
caterpillar13
Reply to edb:
Keep Smiling,
a picture would help, it should have the valve / sediment bowl on it, my guess somebody broke the glass bowl and put that valve in it
Wed, Feb 20, 2019 11:13 AM
beaver-flat
Reply to caterpillar13:
I'll try to get a picture this weekend. previous owner removed the sediment bowl and added a inline filter instead.
possible that this valve came from the local hardware store.....
Thu, Feb 21, 2019 1:13 AM
caterpillar13
Reply to beaver-flat:
most likely, that was my thought when you said ball valve
Thu, Feb 21, 2019 9:15 AM
seyser
Here are the two fuel shutoff valves on my D2 5U.
Thu, Feb 21, 2019 10:17 PM
Inter674
Reply to seyser:
Mm nice pics which confirm my second valve is the same as yours and not one someone hacked up...it's a genuine odd looking piece!
Fri, Feb 22, 2019 3:08 AM
STEPHEN
Reply to Inter674:
Not a fan of the second lower valve. My experience is that anything bad collects in the lower pipes & valve: water & sediments. On donor tractors those pipes are frequently found to be stopped up or rusted through.Also I have had air lock in that system. I had cleaned out the carb & lines, put in fresh gas and couldn't get it running. Took of the carb top and no gas. I had to blow into the tank to get the air out of the lines. My best running D2 has a short line directly from the filter valve to the carb, it seems to work fine. I did have a leaky valve once, but I think the second valve was added by Cat to put all the pony controls on the left side, as I have to walk around the tractor to shut off the gas, I always check the cyl head drains for accumulations before starting anyway. I can guarantee that a rope starting pony will train you in the best way to start it! I hear the class has high attrition rate.
Fri, Feb 22, 2019 4:07 AM
[quote="beaver-flat"]I'll try to get a picture this weekend. previous owner removed the sediment bowl and added a inline filter instead.
possible that this valve came from the local hardware store.....[/quote]
That's exactly what I did to my D2 and D4
Fri, Feb 22, 2019 4:13 AM
