D2 Filters and Gaskets
Showing 1 to 10 of 17 results
Cat Yellow1
Send a private message to Cat Yellow1
Thank you received: 5
hi all,
Trying to figure out oil and fuel filter numbers for my new to me D2. I've read through several threads on the numbers, and from what I can tell, the oil filter is NAPA 1161 or Wix 51161 (Cat number 4A332) and the fuel filter is NAPA 3825 or Wix 33825 (Cat number 7B8262). Am I correct on these numbers? I've seen other numbers on older threads and I'm assuming the numbers I have listed are the most current.
I'm a little more confused about the gaskets. 1) from pictures I see of the NAPA 1161, it shows two o rings that come with the filter. I'm assuming these are the correct o rings. 2) I'm having a little more trouble finding the gaskets for the fuel filters (5B1581 and 7B8037). Would these be the correct gaskets? https://www.napaonline.com/en/p/TWR7B8037 and https://www.napaonline.com/en/p/TWR5B1581. If not, does anyone have a good source?
Tue, Feb 19, 2019 8:03 AM
Mike Meyer
I'm just going through this right now myself, changing out fuel and oil filters on my D2 5U, double check your serial number on your tractor because the part numbers change on the oil filter with the later D2 tractors.
I can't get the part numbers to work with my local Cat Dealer online search for some reason, 7B8262 for the fuel filter group, and for my late model D2, 9F6700 for the oil filter.
Mike
Tue, Feb 19, 2019 9:43 AM
Those appear to be the correct fuel filter gaskets. Notice the correct orientation of the small holes which must align with the vent and clean fuel passages respectively.
The fuel filters are certainly correct. I think I have seen 3 different styles, a sock type with a cloth cover, string wound and even ones with a perforated metal can.
Note, you need 3 elements.
Be very careful with the filter plate and the hardware holding the filters on it. The retaining rods are frequently very brittle plastic and the top with the retainer and pin is easily snapped off. Set the assembly on a flat surface and carefully compress the spring on top. Use a pair of pliers and gently twist and pull the pin straight out. If you stress the bottom of the rod assembly by not pressing straight down on a flat surface, you can easily snap the bottom disk off as well.
The oil filter is correct for the later models with full flow filtration. Earlier models of the U series and all the J series use a bypass type filter with a full flow screen or mesh type outer filter over a bypass type cartridge that is a WIX 31165 / NAPA 1165.
These are usually recognisable by the T bar type nut holding the cover on the filter, but many were converted to full flow with field installed kits supplied by CAT back in the day. Occasionally one shows up that was incorrectly done and the filter is bypassing oil, so check to be sure your filter fits the housing and seals securely top and bottom........especially if your tractor is older than the mid 1950's.
Tue, Feb 19, 2019 10:29 AM
doubleclutch
Send a private message to doubleclutch
Just for some additional info. The latest number from cat for the fuel filters is 489-3196. I just picked up a set from finning for $1 cheaper per filter and they were in stock, I would have had to order in from Napa. The gaskets from cat are now cork gaskets, so I got the 2 gaskets from Napa since they were paper style gaskets. P/N for the gaskets from Napa are 5754 and 5753.
Tue, Feb 19, 2019 10:50 AM
Mike Meyer
Reply to doubleclutch:
Thanks doubleclutch, I'll pass that on to my local Cat Dealer parts guy, do you happen to have the new Cat number for the 9F6700 oil filter too?
Mike
Tue, Feb 19, 2019 11:07 AM
Reply to Mike Meyer:
Mike
[quote="Mike Meyer"]Thanks doubleclutch, I'll pass that on to my local Cat Dealer parts guy, do you happen to have the new Cat number for the 9F6700 oil filter too?
Mike[/quote]
1R0659 is a fairly recent number. Might be a newer one though
Tue, Feb 19, 2019 11:28 AM
Mike Meyer
Mike[/quote]
No, that's the one Jim, thanks for chiming in.
Regards
Mike
Tue, Feb 19, 2019 3:52 PM
Cat Yellow1
Regards
Mike
Thanks all for the help. Mine is a 1949 model (4U1826).
Tue, Feb 19, 2019 4:48 PM
Riverina d4
Send a private message to Riverina d4
Reply to Cat Yellow1:
William Adams gave me this 2 years ago Mike
Hope it was the correct one
Tue, Feb 19, 2019 5:20 PM
Mike Meyer
Reply to Riverina d4:
[quote="Riverina d4"]William Adams gave me this 2 years ago Mike
Hope it was the correct one[/quote]
That's the one, $12.43 plus GST now, the fuel filters are $15.51 plus tax, can't complain about the price of filters from Cat can we, though I'm assuming there will be the 3 fuel filters supplied as 489-3196 plus the filter tower gaskets, the parts number book says that is what comes as the old 7B8262.
Mike
Wed, Feb 20, 2019 2:47 AM
Palmer
Send a private message to Palmer
Mike
Hi Mike,
Just ordered the same filter yesterday (1R-0659) so still good.
Wed, Feb 20, 2019 9:51 AM
