New member with D82u
Showing 1 to 10 of 21 results
Catskat
Send a private message to Catskat
Hi I recently purchased a D82U. I rescued it from the certain death of scrappers. It has been sitting for at least 20+ years. Today i was able to get it fired up and moving. Ive had my eye on this old cat for many years. I ordered a manual for it. I need to adjust the main clutch. I have to pull the clutch lever quite hard to get it to engage. I don't have much experience with these old cats but i have always admired them. This is serial number 2U3408 can anyone tell me what year it was made? Thanks
Sat, Dec 29, 2018 10:11 AM
Sasquatch
1947 model year, production started at #2U2126 and ended at #2U4592. Glad you were able to save her from the scrappers, and welcome aboard!
Sat, Dec 29, 2018 10:23 AM
Reply to Sasquatch:
Bravo! Nice Save.
Sat, Dec 29, 2018 10:33 AM
Catskat
Bravo! Nice Save.
Ah Sasquatch ive been watching your videos on YouTube. Keep it up! Thank you for the information. It sure was exciting seeing this old gal come back to life today. I have a D47J i messed with this summer. But the engine was seized and after many hours of work i was unable to break it loose. But the price was cheap enough i just parked it in the yard as a display piece.
Sat, Dec 29, 2018 10:52 AM
Catskat
Reply to Catskat:
Here are some more pictures
Sat, Dec 29, 2018 11:08 AM
ag-mike
Reply to Catskat:
kinda big 1 for a new member, good luck with ur project.:welcome:
Sat, Dec 29, 2018 11:15 AM
Bruce P
Reply to ag-mike:
Welcome and congrats!! That looks like a real sweetheart!!
BP.
Sat, Dec 29, 2018 12:09 PM
Andrew
Reply to Bruce P:
BP.
Great find.
I have found the clutch plates must swell slightly on a dry clutch machine like yours that hasn't been used for a long period.
If you cant put up with it loosen the adjustment slightly. You will be tightening the adjustment after a bit of use..
You need to know how to adjust and lubricate the clutch.
Clutch adjustment and lubrication is part of a operators daily routine.
When using these dry clutch machines, although the book says not to , I keep a squirt bottle of thin oil on the machine to squirt oil on the over center linkage pins. . This makes clutch use a lot easier and smoother.
Sat, Dec 29, 2018 4:57 PM
Thank you received: 19
Reply to Andrew:
Great find.
As per Andrew saying oil the linkages on the clutch it helps but from experience that is not the end of the story.
As a kid learning close up tillage of walnut trees with a 4r D6, no protection from limbs the clutch needed to working well as it was life and death. Besides greasing the old guy instructing said a little oil on the clutch linkage helps.Well one day I cannot get in disengaged, so shut it down and went for the old guy.
"Have you been oiling like I show you", yes of course. "When was the last time you washed it with gas", he forget to tell me that part. If you start getting a build up of dirt,splash some gas and some compressed air to clean and start over with oil. I am not familiar with the changes but if your clutch is enclosed rather than out in the open it will not get caked in dirt near as fast.
This was very dusty conditions and the 4r and 5r had no cover to keep dust off as the newer 8u and 9u have with the same clutch.
Sun, Dec 30, 2018 12:16 AM
Reply to Ray54:
Wear on the Pin Bosses in photo4 suggests the Rollers are shot!
If its a few hours a year machine, no big deal!
If you are planning to use it, then either replacement or reconditioning is in order.
Sun, Dec 30, 2018 8:51 AM
Catskat
Reply to drujinin:
Finally got it home yesterday. Im still waiting on my manual to show up. I couldn't figure out how to adjust the clutch. So it was slipping pirty good going up hill. But i got it into position where i want it. The wear on the pin bosses i believe is from the lower sheild here. Forgive my terminology im sure theres a proper name for it. But its definitely mangled enough to be making contact with the links.
Thu, Jan 3, 2019 11:03 AM
