Early Diesel Powered Tractors
Showing 1 to 10 of 16 results
Thank you received: 19
Rainy day reading on Unofficial Allis Chalmers forum I have come across information on Kaiser converting Monarch tractors as well as the Cat 60's that have been reported here.
There is information discovered that one of the Monarch 75 tractor may have been in a U C Davis collection at one time. I figured if such a tractor was in a somewhat public collection someone here may have seen it, or at least confirm it's existence.
Thu, Nov 29, 2018 3:10 AM
Thank you received: 40
Hi, Ray54.
If my memory serves me rightly. R. G. LeTourneau mentioned in his autobiography that he and Kaiser dropped a diesel engine into a crawler back in the late 1920s. Again, if memory serves a-right, they were impressed with the extra that it achieved and the lesser amounts of fuel consumed - - - right up until it shook itself to pieces 'cos it wasn't designed for mobile use. I suspect that it may have been one of the Atlas diesels but I'm not sure about that.
The early diesels were mostly designed for stationary applications and didn't really get 'mobilized' until Mercedes Benz and then Cat designed diesel engines with crankcases and cylinders cast in one rigid block to give them the strength needed to cope with both the higher operating pressures and the banging around of mobile applications.
As I understand it, it was a Mercedes Benz diesel that beat the pants off a gas-powered Cat Sixty in a plowing competition in 1030-31 and started Cat into developing their own diesels. Again, as I understand it, they went and bought a Mercedes Benz Diesel and had a mechanic, a man named Art Rosen, strip it down to the last nut and bolt to find out what made it so much better than their gas-powered engines and then design an engine to match or beat it. If you have a look at the early Cat Diesel Sixties, the engines look remarkably like M-B diesel engines up until the late 1950s at least.
Thu, Nov 29, 2018 4:16 AM
JDcat
Send a private message to JDcat
Hi, Ray54.
Contact Jeff at Vintage Tracks Museum in Bloomfield NY. He may be able to provide some information also. I believe he has some Monarchs in his collection.
John
Thu, Nov 29, 2018 5:47 AM
Thank you received: 78
Reply to JDcat:
John
Here you go Ray. I’m crossing the line with orange, but here it is!
Thu, Nov 29, 2018 8:59 AM
Casey Root
Juiceman. Looks like you found and acquired your HD 6 AG. Tell us the saga and pictures please.
Thu, Nov 29, 2018 9:49 AM
Skinner
Reply to Casey Root:
Juiceman so you went right through my town and didn't even stop by what's up with that ? Ha ha 🤔
Thu, Nov 29, 2018 10:50 AM
gauntjoh
Librarian
Reply to Skinner:
There is an ATLAS engined Cat 60 here in the UK.
Fully restored and owned by a collector.
I'm not sure I have any pictures of it but I will take a look when I have a bit of time.
It starts on compressed air and has one exhaust stack for each of the four cylinders.
Thu, Nov 29, 2018 1:52 PM
Reply to Skinner:
Oops! I forgot to pay the toll keeper......
I sure wanted to stop in and visit, but us poor people have to keep the wheels turning! I’m guessing you knew the CL seller? He had a ‘47 KW project and some hot rods that I admired.
Casey: It is an HD-6E; I wish it were an “AG”. Considering its a 1956, it’s in very good condition. Only issue I noticed is it’s addiction to ETHER! I don’t know if I can “wean” it if it or not, but UC is nice, and doesn’t smoke at all. Just needs the correct batteries and a new generator...
Not much of a tale to tell, I noticed it on CL and inquired. Another WANT, not NEED! It was either sell my AC disc and ring roller, or buy an orange tractor to match it LOL. The hardest part of the nocturnal road trip was to be able to sneak thru “enemy” lines without being detected! Upon my arrival, the seller had indicated that he had already dealt with some of my ACMOC pals. He has a bunch of antique wheel tractors for sale if anyone is interested. He is motivated to sell them.
I have to guess that the tractor won’t be able to handle the disc like my D4D SA, so I will keep looking for an HD-6E AG, or an HD-9.
Thu, Nov 29, 2018 5:06 PM
Casey Root
Hauling with that sweet Pete, it is NOT camouflage so yes, a trip in the dark would be necessary.
All of our ACs liked a snort of either in the morning. The Detroit power required the drug and we thought the HD 11 AG would be addiction free. Not the case. Even with a fresh engine rebuild it still needed a snort. It would probably do better on today's low sulfur fuel. My D6C starts a lot easier today than the old one used to.
We have run a couple of HD9s and with the stock 2 valve engine, they performed about the same as a 9U D6, maybe a bit less. Take that Detroit to an "N" series 4 valve engine and now you have some snort. On level to rolling ground we pulled a 21 ft disc in 4th and 5th gear. In the steeper stuff an 18ft was easier on the frictions and traction was an issue. One of our old HD9s is still running and working west of Templeton.
Thu, Nov 29, 2018 11:07 PM
janmeermans
Hey JM,
Did you sneak that right out of Ray54's neighborhood without giving notice? Maybe he would have met you when you loaded it and you two could have discussed at length the Monarchs in the CalAg Museum. Then to snub "skinner" on the way home! I guess you were in a big hurry to get your next load at the Port of Stockton. Oh well!
By the way, good on you for helping the fire ravaged folks up north with the proceeds from your D6 sale! If your brother has a change of heart, our AGSEM museum down here could sure use a nice 416! 😊
JanM
Thu, Nov 29, 2018 11:41 PM
Barstart
Send a private message to Barstart
No Monarch at UCD. Diesel Caterpillar 60, serial number 1C1 is there, but definitely no diesel Monarch, unless it was actually used for farming and sold a long time ago, and never part of the collection.
Sue
[quote="Ray54"]Rainy day reading on Unofficial Allis Chalmers forum I have come across information on Kaiser converting Monarch tractors as well as the Cat 60's that have been reported here.
There is information discovered that one of the Monarch 75 tractor may have been in a U C Davis collection at one time. I figured if such a tractor was in a somewhat public collection someone here may have seen it, or at least confirm it's existence.[/quote]
Fri, Nov 30, 2018 12:41 AM
