How to operate d7n winch
Showing 1 to 9 of 9 results
Rwhi2018
Send a private message to Rwhi2018
Just picked up a 1959 d7d 17a in fair condition. Everything is working good cleared a few acres of land with the old girl so far. But I would like to know how to use the winch. The previous owner said they didn't ever use it nor didn't know how to use it but I would like to learn. If anyone can tell me the steps of operation it would be grately appreciated. Thanks.
Tue, Nov 13, 2018 7:02 AM
Theres a bunch of manuals on ebay for Hyster d7d winches.
Tue, Nov 13, 2018 7:53 AM
Rwhi2018
I did purchase a manual from Jensales.com after reading the 354 pages there was no information on the winch or hydraulic system. Before I spend another 60$ American on another manuel just so I can know the sequence of how to turn on the winch. I was hoping someone could just inform me of how to engage the d7n winch on a 1959 d7d 17a tractor.
Tue, Nov 13, 2018 6:37 PM
Reply to Rwhi2018:
Jensales are not good manuals, the original Hyster parts and instruction manual shows everything. The longer lever is the brake, forward is the released position back is the brake hold position, The shorter lever is the control lever, to pull cable in lever is pulled back and main clutch engaged, center position of lever is neutral, forward is the release position to let out cable. That is for an over winding winch. Always release the brake before using the winch. Only apply the brake when tractor master clutch is disengaged or the tractor motor will be stalled.
Tue, Nov 13, 2018 9:50 PM
Machias cat
Send a private message to Machias cat
Go here: http://www.alliedsystems.com/pubs/pubs.htm# click "allied winch" then "operator's manuals" then "archive"
It's this one for the D7N: http://www.alliedsystems.com/pdf/Winch/Manuals/599200W.pdf
Tue, Nov 13, 2018 11:44 PM
greengiant
Send a private message to greengiant
Reply to Machias cat:
Thanks Rome and Machias for the winch info. Now I need manuals for adjusting track tension and front CCU on my D7-D. I have searched ebay and google to no avail.
Wed, Nov 14, 2018 8:11 AM
greengiant
Reply to greengiant:
I should mention that last weekend while exercising my D7-D before putting it away for the winter there was a very pronounced metal on metal sound both while running and while idling. I couldn't pin it down but was afraid it might indicate transmission failure. I got out of the cab to look around and saw that the winch was turning. I had inadvertently activated it while climbing in past the levers. the metal on metal was the big hook coming around and striking the frame. lucky it went past each time and didn't hang up.
Wed, Nov 14, 2018 8:29 AM
Catboy1
Send a private message to Catboy1
One other thing, if it’s the same as my D6N, you can’t be in gear while running the winch, or serious transmission damage can occur. Most likely the engine will stall, but that’s what it says in my manual.
Wed, Nov 14, 2018 9:54 AM
kracked1
[quote="greengiant"]Thanks Rome and Machias for the winch info. Now I need manuals for adjusting track tension and front CCU on my D7-D. I have searched ebay and google to no avail.
'[/quote]
If all else fails your dealer will have the books. You need to search by serial number not model, such as d7d. Also you ccu will be its own book I believe.
Wed, Nov 14, 2018 8:27 PM
greengiant
Reply to kracked1:
'[/quote]
thanks, I hadn't thought of the dealer.
Thu, Nov 15, 2018 8:08 AM
Earlcoate Charity Open Day
