torn gasket between the clutch housing and the engine oil pan
Priceless
Send a private message to Priceless
I have taken the oil pan off my 17A and in doing so it took a piece of the gasket off between the clutch housing and the engine oil pan--although the correct thing to do is pull clutch and replace the gasket, I figure I might as well repair the gasket. If it doesn't hold I won't loose any time or have to redo the oil pan on the engine.
Old Magnet says on 05-23-2016, 11:34 AM The only info I can offer is use Aviation gasket cement on assembly instead of grease. A few others stand by the Aviation gasket cement.
My question is this--in this situation what is the best repair cement should I use? While I am asking should I put the Aviation gasket cement on both sides of the oil pan gasket or just the block side. ( no, unlike the manual says, the pan didn't magically fall off leaving the gasket in one piece)
Sun, Nov 11, 2018 9:54 PM
I would use silicone gasket maker instead of the brush-on. I usually only apply it to the "unstuck" side of the gasket and any tears, leaving good, stuck gasket in place on whichever part it is on. That is how I would use the brush-on material as well and I have a bottle of it in my tool box right now, but I think the silicone will seal bigger gaps from missing chunks of gasket etc.
Mon, Nov 12, 2018 10:04 AM
restore49
Ford or GM anaerobic gasket maker designed for Super Duty Diesel oil pans.
Wed, Nov 14, 2018 5:32 AM
Cdcompton
Send a private message to Cdcompton
Reply to restore49:
Why repair a bad gasket go to the local auto parts store and get a roll of fiber material and a ball pien hammer and make one. On newer stamped oil pans they usually have a ressesed area to hold gasket maker, that cast machined face likes gasket and aviation glue my 2 cents i would not personally hope that an old gasket has not seperated underneath on the bottom side to a degree and could begain to seap after vibration.. like the old man says do it right do it once. 😊 good luck
Wed, Nov 14, 2018 7:23 AM
Priceless
Reply to Cdcompton:
I have been cleaning parts and chasing threads on bolts, but will get to replacing the pan this weekend. I plan on patching in the gasket that was torn out with the "Ford or GM anaerobic gasket maker designed for Super Duty Diesel oil pans". I am hoping this works as the clutch housing won't have any pressure in it, or at least I don't think it will. If it leaks I will have the engine closed up and tackle that on another day. I have already bought a oil pan gasket $32.00 I can't make one that cheap although I did make one for my RD 7 as Cat didn't have one.
On another subject where do I find the lock to the idle adjust on a Zenith Carb. Cat Part 5F7678? mine broke and Cat doesn't have one.
Wed, Nov 14, 2018 7:34 PM
Priceless
Reply to Priceless:
On another subject where do I find the lock to the idle adjust on a Zenith Carb. Cat Part 5F7678? mine broke and Cat doesn't have one. I have tried to find a few places online and no one has one, just rebuild kits. What kind of Zenith carb is this? If I can't get one how do I keep the ilde valve shaft screw from vibrating out of the carb? (blue locate, maybe a spring between the carb body and the head of the screw, surly someone has had this problem).
Sat, Nov 17, 2018 7:15 PM
An online search for that part number returns several hits including FP Smith and an ebay listing by Arkansas Diesel Service.
Wed, Nov 21, 2018 8:11 AM
Priceless
ccJersy, Thanks, I have ordered the part and learned more on searching for parts. Lex
Wed, Nov 21, 2018 8:02 PM
Doesn't always work, but you will find stuff that the CAT parts guys cannot get anymore....and plenty they can!
Wed, Nov 21, 2018 8:30 PM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
