Need help D4 7U13292 hydraulics
Showing 1 to 10 of 12 results
Ron
Send a private message to Ron
I had a hydraulic cylinder rebuilt on D4 7U.
Cat has not ran in a couple years.
I cannot get the blade to lift up now, after I replaced cylinder.
Hydraulic fluid is full.
Any help will be appreciated!
Thanks,
Ron
[attachment=51233]32F96C08-F1D4-40FD-BCD3-604DEF73DFA3.jpg[/attachment]
[attachment=51234]D03E150C-5D3C-499D-8F78-B2A2CE1F1AD7.jpg[/attachment]
[attachment=51235]797FBFD9-7DF5-4B05-9467-D999F90212C4.jpg[/attachment]
[attachment=51236]FC5DF173-5ADB-4493-A50B-A458AF283699.jpg[/attachment]
Sun, Oct 28, 2018 3:27 AM
CatManMark
Send a private message to CatManMark
Have you checked the rest of the hydraulic system? Pump/valves/controls?
Sun, Oct 28, 2018 4:54 AM
cojhl2
Reply to CatManMark:
Ron, can you hear any hydraulic noise when pump is running and a direction valve moved.
Did this work albeit poorly before you worked on the cyls?
Sun, Oct 28, 2018 5:32 AM
Ron
I guess that is part of my question. Where do I start first and how do I check it?
Sun, Oct 28, 2018 5:44 AM
Ron
Reply to Ron:
It is not making any noise when I move the lever. When it was cold in 20’s very slow at first until warm.
Sun, Oct 28, 2018 6:10 AM
CatManMark
Reply to Ron:
Check you pump for pressure and oil flow first and work your way back.
Sun, Oct 28, 2018 6:17 AM
nomorejohndeere
Send a private message to nomorejohndeere
were ya moving the lever the right way?
Sun, Oct 28, 2018 6:26 AM
Reply to nomorejohndeere:
What weight oil are you using? If it's to thick nothing will happen when cold.
Sun, Oct 28, 2018 6:34 AM
caterpillar13
you may have a broken pump shaft, that happened on my D2 5U.
Sun, Oct 28, 2018 7:13 AM
Chuck C
Reply to caterpillar13:
Try checking the hoses. Make sure they are hooked up right.
Chuck C
Sun, Oct 28, 2018 7:24 AM
Ron
Reply to Chuck C:
Chuck C
Here is a picture of the fluid I use.
Temperature outside is around 50 degrees.
Could I crack a hydraulic line and see if I can get air out of it?
Thanks!
Sun, Oct 28, 2018 7:47 AM
