how to free stuck valves
Priceless
Send a private message to Priceless
My 17a starting engines two center valves are stuck ( l left the carburetor off for too long) what is the best way to unstick them without taking the head off of the engine. Any body parting out a 24 or 25 ccu around Kansas? Thanks
Sat, Oct 27, 2018 8:48 AM
Steve A
if you have access to the valve stem under the access cover you can usually clamp on to the end with needle nose vise grips and wiggle them back n forth or use a standard screwdriver as a wedge between the lifter and valve to push them up more.
Sat, Oct 27, 2018 9:11 AM
Priceless
Reply to Steve A:
Thanks I had thought of using a dowel rod in the spark plug hole be am worried about bending the valve. I will try your idea as it would put a straighter
force on the stem.
Sat, Oct 27, 2018 10:28 AM
Priceless
Reply to Priceless:
force on the stem.
I put feeler gauges between the valves and push rods and turned the engine over, then I took a brass punch to knock them back down (through the spark plug hole. put it back together and it started first turn. My next question is has any body had the main engine full of water (4 gal on this D7)
and what did you do before attempting to start the engine? I plan on taking the oil pan off to inspect and clean up the gunk--I also will inspect the
oil pump. The valve train has some rust so I will take it apart and clean that up. What else? Thanks
Wed, Oct 31, 2018 8:31 AM
| Hartley - South Australia
