Where to Find Pre-Filter Glass Jar for D2 Air Filter?
Showing 1 to 10 of 14 results
rhartwick
Send a private message to rhartwick
The glass jar pre-filter has been broken on my D2 5U. I thought they took a wide mouth mason jar, but they are too small. The base fragment of the old jar had a ring that fit into the screw, so I guess these are not any general purpose jars. I can try Cat, as I didn't see any on EBay. Am I missing something, or were these jars special? I thought I remember fitting a common mason jar to my old D4 7J.
Mon, Oct 8, 2018 6:12 PM
Crawler Dollars
I just went through the same issue. The correct mason jar is the half-pint 'SPECIAL' jar. The low 'ring' on the 'SPECIAL' is a little larger in diameter that the standard half-pint. There were a few on e-bay just a couple of weeks ago, although a little pricey. I ended up buying the Cat plastic jars on e-bay.
Mon, Oct 8, 2018 8:47 PM
STEPHEN
Reply to Crawler Dollars:
The correct fitting jar for your model is the plastic jar, so far as I know. It has a metal reinforcing ring around the fls.ge.
Mon, Oct 8, 2018 9:05 PM
nomorejohndeere
Send a private message to nomorejohndeere
Reply to STEPHEN:
would you share a link to the plastic jars? my search comes up no results
thanks
Mon, Oct 8, 2018 9:53 PM
brewzer
Reply to nomorejohndeere:
thanks
I have a few of the glass jars. Email me if interested.
Wally
Mon, Oct 8, 2018 9:57 PM
rhartwick
thanks
[quote="nomorejohndeere"]would you share a link to the plastic jars? my search comes up no results
thanks[/quote]
I hadn't been able to find the jars on EBay, but finally came up with this listing.
https://www.ebay.com/itm/CAT-Caterpillar-5F-6658-Jar-Assembly-5F6658/271874395410?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2648
They list this for a D4. Is it the same as for the D2?
Thanks to everyone for the replies and help.
Mon, Oct 8, 2018 9:59 PM
Crawler Dollars
Reply to rhartwick:
thanks[/quote]
[quote="rhartwick"]I hadn't been able to find the jars on EBay, but finally came up with this listing.
Thanks to everyone for the replies and help.[/quote]
Yes, this is the same seller that I purchased mine from.
Mon, Oct 8, 2018 11:41 PM
Stuss
Send a private message to Stuss
Hi. Over here the original glass jars are Ball , we could only get plastic ones from Cat. But we got Ball jars from Steiner , IHS727
Tue, Oct 9, 2018 5:36 AM
josh
Thank you received: 6
Reply to Stuss:
There are at least two different kinds of jar type precleaners, the older one ,5B2751, that was just available for a year or couple around 1939, is threaded and used the Ball type jar 5B2746, which is specified as "Jar-Wide mouth" and ring 5B3323. The clamp type precleaner uses the 5F6658 jar and 5B3323 ring.
The jar for the threaded precleaner updates to 6L7648.
Tue, Oct 9, 2018 9:36 AM
d2gary
Reply to josh:
My wife actually collects canning jars and the ball specialwide mouth actually aren't that special. Collectors value is under $10 As a matter of fact she just canned 2 cases of jalapeno candied peppers
[attachment=50997]20181008_200510.jpg[/attachment]
Tue, Oct 9, 2018 10:13 AM
Reply to d2gary:
Hah! I'll take six jars with the jalapenos!
Tue, Oct 9, 2018 10:32 AM
