D7 17A hydraulic control unit.
Showing 1 to 10 of 13 results
enos
Send a private message to enos
I recently purchased a later model D7 17A or D7D with the front driven hydraulic control unit. Is this a #46 unit? Is there a tag on the hydraulic unit somewhere. I need a manual for the hydraulic unit. I am in the process of removing the D339 from the dozer as a rod put a nice viewing window in the side of the block. I am sure many questions will follow.
Thu, Sep 20, 2018 10:29 AM
Yes, that would be a #46 Hydraulic Control s/n 48C1-up. Also known as a 173 Hydraulic Control s/n 48C1-up.
Thu, Sep 20, 2018 11:36 AM
bluox
The 46 is a front hyd. unit and the 173 is a fender mount unit , two completely different systems.
Bob
Thu, Sep 20, 2018 10:13 PM
Reply to bluox:
Bob
Wrong again and I have the Service Manual to prove it.
Thu, Sep 20, 2018 10:33 PM
Kelly
Show us what you got there on the Service Manual OM.
Kelly
Fri, Sep 21, 2018 12:00 AM
seiscat
Reply to Kelly:
Kelly
The D7 17A used the #46 hyd. control. The manuals are sometimes available on ebay. I also have the manuals and I will help if you tell me what info you need.
The #46 hyd. control was also used on the D7E; Old Magnet is correct, it was then called the 173 hyd. control. There were three hyd. controls available on the D7E. The 173 was the front mounted unit, the 172 was the fender mounted unit and the 171 was used to operate a tilt cylinder on cable blade equipped D7E tractors.
[attachment=50787]172&173.jpg[/attachment] [attachment=50788]171 hyd control.jpg[/attachment]
Craig
Fri, Sep 21, 2018 2:22 AM
Reply to seiscat:
Craig
Then the later D7E's had the 173B 34H series system on the fender with the lower long tank.
Fri, Sep 21, 2018 2:53 AM
Reply to Kelly:
Kelly
[quote="Kelly"]Show us what you got there on the Service Manual OM.
Kelly[/quote]
Check ebay for yourself, 173 Service Manual is about 20+ pages, also Parts and Operators Manual. Very good detail on servicing the #46 Hydraulic Control.
Fri, Sep 21, 2018 4:54 AM
Kelly
Kelly[/quote]
MO. I don’t have to check e-bay I have the service manual.I just thought someone else would be interested in what you said you had as well-------but that’s ok.
Bob is right as well 173 Sn 65g1 and up, and 173 Sn 67g1 and up was fender mounded tanks also.
Kelly
Fri, Sep 21, 2018 2:30 PM
Reply to Kelly:
Kelly
I specifically stated 173 s/n 48C1-up
Fri, Sep 21, 2018 11:09 PM
seiscat
As always our aim is to never let a nit go unpicked...lol. Going back to the original post that asked for info on a D7 17A #46 hyd. control, Old Magnet correctly posted that the #46 control was the same as the 173 control 48C1 - UP. I don't know why Caterpillar changed the 172 control to the 173 control but it has caused the confusion in this discussion. I have attached the pics from my previous post that show the 171, 172 and 173 controls.
[attachment=50799]171 hyd control.jpg[/attachment] [attachment=50800]172&173.jpg[/attachment]
Craig
Sat, Sep 22, 2018 2:23 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
