7T867 Grader
7T867 Grader
Showing 1 to 7 of 7 results
eric jensen
Send a private message to eric jensen
My question is about the rear rims on my 7T grader is there a safer rim to buy other than the spit rim thats on it it has the split rim with the two locking pins in ether side of the spit part of the rim or should i take them off and let the tire guys fight with them
Mon, Sep 17, 2018 7:22 AM
old-iron-habit
Could you show a picture of your rim?
Mon, Sep 17, 2018 9:15 AM
eric jensen
Reply to old-iron-habit:
Sorry for the bad picture if you zoom in you can see in the left the two pegs in the split ring I wil get better pictures this week
Tue, Sep 18, 2018 1:28 AM
The rims on Caterpillar equipment are not the Widowmaker type. I have never questioned whether one would hold as it was being inflated but I do use a clip-on chuck and back away once the bead seats and pressure begins to build.
I am unfamiliar with the pegs you are describing but I have seen wheels where the locking ring was riveted onto the rim flange on one side of the split so it would not be lost or perhaps mismatched.
First some terminology so you know what I am talking about.......the rim base is the large section with one rim flange and the cleats or center to mount the assembly on the machine. Then there is a removable outer flange ring with a tapered bead seat on the inside and a chamfer cut in its outer surface to squeeze the lock ring tightly into its groove in the rim base, locking the rim flange ring securely onto the rim base.
The trick is to get the locking ring to fit tightly in its groove and clean all rust and dirt from the parts so nothing interferes with it gripping the rim base and being compressed tightly by the rim flange ring moving outward. If it doesn't fit perfectly, usually it is bent open a little so it doesn't grip the rim base tightly. If its bad i might try reshaping it by running it through a clevis or jaws of a vise and springing it closed with hand pressure or possibly using a tool of some kind. The end result should be a ring that is flat and whose ends butt up together. When you spring this open and force it into the groove in the rim base it holds itself in place until the flange ring moves out and traps it.
Obviously if the rim base groove or the lock ring are rusted badly, so they do not engage securely, do not try to reuse the parts,
When the lockring is just a little loose in its groove, I will clamp it in the rim base groove with several pairs of visegrips spaced evenly around the circumference. You should be able to clamp the pliers on so the jaws don't prevent the flange ring from moving outward and trapping it the lock ring so it cannot slip out of its groove as the flange ring tightens against it. The flange ring may have to push the visegrips out of the way as it moves out all the way, so do not put them on too tightly.
Finally you need lots of tire mounting grease and plenty of air.
Put a good coat of grease on the beads of the tire, put it on the rim,
put the flange ring on and press it down into the upper bead of the tire so it seals.
Put o-ring in its groove in the rim and coat it with grease.
Install lock ring as described earlier.
Remove valve core and attach airline to the stem and inflate tire pushing the flange ring up against the lockring and sealing against the o-ring.
If you cannot get air in fast enough to expand the tire and push the flange ring up, you can use handsful of the grease to pack the area between the flange ring and rim base. The stiff grease will allow enough pressure to build up inside the tire to move the beads out. Once you get this going right you don't want to be monkeying around with the lockring, wondering if it is tight in its groove etc. Take care of that ahead of time!
Tue, Sep 18, 2018 6:02 AM
STEPHEN
Caterpillar never used spit rims. They did use multi-peice
demountable wheels like most heavy equipment did back when.
Tue, Sep 18, 2018 6:15 AM
eric jensen
Reply to STEPHEN:
When I look at the rim it looks like it has one lock ring and it is tube tire the lock ring looks like one on a truck not the multiple pice like on a loader
Tue, Sep 18, 2018 7:43 AM
Even better!
No monkeying with the separate lock ring, o-ring, grease etc. I think you will have a removable flange ring with a split in it so it can be pried open and off the rim after you drive the bead down off of the tapered bead seat.
I was looking through my 12e grader parts book for diagrams showing the different wheels available and I saw this one for tube type wheels. It is different from any i have ever seen. I doubt it is what you have since it would obviously have 2 separate rings instead of one, but I thought I would post it just in case. Looks like the split inner ring that the tire bead compresses into the retaining groove on the rim base is also restrained by a complete circle of the removable flange that slips over it.
Tue, Sep 18, 2018 9:38 PM
eric jensen
Even better!
Thanks for the incite on the rim
Thu, Sep 20, 2018 4:51 AM
