Hydraulics working slow
Showing 1 to 7 of 7 results
clayton
Thank you received: 11
Hi I have a 1945 D74T on the reservoir it leaks just a little where the arm on the top rotates, haven’t found anything else wrong is there a procedure to bleed the air out or a filter that needs replaced? It raises the blade up but the blade won’t stay up it slowly goes down it will lift the front of the crawler up and hold it for awhile any thoughts are much appreciated thank you
Fri, Sep 14, 2018 8:35 PM
catsilver
Could be cylinder seals leaking or a poppet valve in one of the cylinder pistons sticking/broken/ leaking. If you can get it warmed up, the leaking cylinder will be warmer than the other, or listen to the cylinders with a stethoscope while they are dropping (with the engine shut down) and you will hear which one is leaking.
Fri, Sep 14, 2018 9:40 PM
Thank you received: 32
Reply to catsilver:
Explain futurer, title is hydraulics working slow. Then you go on to describe blade settling as from a leak.
Very common that the control valve would leak on something this old. Generally the leak is inturnal so you will not see oil dripping. But the packing in the cylinders leaking internally is common with age as well.
So back to title has the speed of blade movement also changed? Just trying to understand the problem so we are fixing the part you meant,and not what thought I heard.
Fri, Sep 14, 2018 10:28 PM
nomorejohndeere
Send a private message to nomorejohndeere
Reply to Ray54:
howdy neighbor
does the blade go up smooth after sitting or does it seem to hesitate or jerk its way up the first time?
then get smoother the second time around ?
meaning is there some air in there getting displaced
Sat, Sep 15, 2018 9:32 AM
Reply to nomorejohndeere:
howdy neighbor
Tagging on to this thread, will my D2 hydraulics need to be bled? I replaced everything and the system is bone dry (except I refilled the reservoir obviously...)
Sun, Sep 16, 2018 3:44 AM
Andrew
Simply raise and lower the blade repeatedly until every thing is working correctly.
You may have to top up the reservoir while doing this .
Good luck .
Sun, Sep 16, 2018 4:09 AM
Reply to Andrew:
Good luck .
Righto - thanks Andrew
Sun, Sep 16, 2018 8:50 AM
DWC7
Send a private message to DWC7
What you described with the blade bleeding down tells me first thing i would do is rebuild the cylinders. This can be done yourself easily. You should have a local seal house that can order you the correct seals. Just pull one of your cylinders apart pull all of the seals and take them to them.
Mon, Sep 17, 2018 10:27 PM
