1693 Cat - Pump tuning
Showing 1 to 10 of 50 results
1972RedNeck
Send a private message to 1972RedNeck
Picked up a '77 W900a with a 1693 with 60,000 miles on an overhaul. Starts and runs like a top. Currently set to 325 HP. Mostly just going to be a fun truck to make a little noise and blow a little smoke and maybe haul a little bit of grain every now and then.
I would like to get it tuned up to 425 HP. As far as I can find, the only difference between the 325 and the 425 is the addition of the JWAC and rack setting.
Anyone on here know enough about these old beasts to walk me through turning the rack setting up to 425 - 450 HP? Local Cat dealer doesn't have anyone with a clue...
Sun, Aug 26, 2018 8:14 AM
Where ya located?
Sun, Aug 26, 2018 8:56 AM
1972RedNeck
Where ya located?
Montana.
Just ran across an old thread on ATHS claiming that the 425 versions had a different turbo as well. True or false?
Also claimed to have been available up to 525 HP in other applications - True?
Sun, Aug 26, 2018 9:12 AM
catsilver
Reply to 1972RedNeck:
Montana.
Many checks to be made, different turbo, possibly different pistons and a different fuel pump camshaft, I have detuned marine engines by just the rack setting but getting more power is not always as simple as it looks.
Sun, Aug 26, 2018 3:31 PM
1972RedNeck
Reply to catsilver:
I have done as much checking as can be done on the interweb, it looks to me like everything is the same betwixt the 325 and 425 except the JWAC and maybe the turbo.
I don't have a serial tag on my engine otherwise I would try to look it up on Cat parts.
I would like to find an old timer that knows these engines like the back of his hand that I could talk to to glean some information from him.
Sun, Aug 26, 2018 7:32 PM
catsilver
You could probably go up to around 400hp fairly safely with just the turbo and aftercooler but will also need higher revs to get hp meaning that unless you change gear ratios you won't gain anything on acceleration and will have to keep it buzzing to make use of the extra power. The downside is reduced reliability, unless you actually need the extra power and can find the correct parts to do it, leave the old girl as she is and enjoy the low down grunt from that lovely old twin cam engine.
Sun, Aug 26, 2018 9:14 PM
Thank you received: 23
Reply to catsilver:
Does Cat have an equivalent to the Cummins CPL, which is where you can look up all the parts for an engine's specific rating? If so, that will be the place to go to find out what you need, by comparing it to the CPL for your 325 rating
Sun, Aug 26, 2018 9:56 PM
catsilver
Cat have their rack setting charts and the different arrangements for different horsepower are listed in their parts books, unfortunately, you need the engine serial number, arrangement number and bill of material numbers which are on the engine ID plate to correctly identify it and compare with others to see what you need,
Sun, Aug 26, 2018 11:28 PM
bluox
Reply to catsilver:
As far as I know only 1 serial #for a 1693 65B0000 but there are at less 3 # breaks that involve different parts one being a spacer plate engine. I only worked on a few but have worked on D-343 engines So far from a expert.
I'm of the same opinion as catsilver ,if its not broke leave it alone. I have seen more than a few engines burnt down by wantabe experts turning up the fuel. Anyway it's yore engine carry on.
Good luck
Bob
Mon, Aug 27, 2018 1:42 AM
Reply to bluox:
Good luck
Bob
That sounds good catsilver, sounds just like the CPL. It's so easy to build an engine to spec with that.
Mon, Aug 27, 2018 2:29 AM
1972RedNeck
Reply to bluox:
Good luck
Bob
[quote="bluox"]As far as I know only 1 serial #for a 1693 65B0000 but there are at less 3 # breaks that involve different parts one being a spacer plate engine. I only worked on a few but have worked on D-343 engines So far from a expert.
Good luck
Bob[/quote]
I agree on most points. I could increase the rack travel myself in less than 5 minutes but I'm not going to as I have no idea what I am doing as far as how much to give it. That, and if the engine is not built to take it, I am plumb content at 325 HP.
But if it is only a matter of adding a JWAC and swapping turbos to get a reliable, Cat spec 425 HP engine, why not? If I need different precups, pistons, etc., it will remain as is.
I just bought a service manual off ebay that has a rack setting book included. Will that outline the differences in engine internals, if any?
Mon, Aug 27, 2018 3:00 AM
Price Tractor Pull
Price Tractor Pull
