D6b track adjuster diagram
Showing 1 to 10 of 13 results
dogwalkin
Send a private message to dogwalkin
I have purchased a d6b sn 44a113xx
Does anyone have an exploded diagram showing the track frame with the adjuster. The previous owner took it apart sometime back. I now have do put it back together to move it and load it. Thanks in advance.
Clyde
Sun, Aug 19, 2018 7:07 AM
Manual or hydraulic adjuster?
Sun, Aug 19, 2018 7:12 AM
dogwalkin
Hydraulic.
Sun, Aug 19, 2018 7:26 AM
Reply to dogwalkin:
Hydraulic.
It's never easy. There are four different types. In general the early ones have a four bolt cover to retain the seal between the cylinder and the piston. Latest style does not. A picture of the parts would help identify.
Sun, Aug 19, 2018 7:48 AM
dogwalkin
I'll see if I can post a pic tomorrow
Sun, Aug 19, 2018 8:03 AM
dogwalkin
Reply to dogwalkin:
Mine has the 4 bolt cover. I wanna make sure I'm not missing anything since he took the spring and all loose from the track frame.
Sun, Aug 19, 2018 8:19 AM
Reply to dogwalkin:
This should cover it...
Tue, Aug 21, 2018 9:45 AM
dogwalkin
Thanks!! That shows me what I need. Now the tracks on the machine are shot. There is a set of tracks that look really good that go with it. It already has segments on the rear sprocket they are berco cr 4409. The number on the track links are d5h/190 these are correct right??
Also I'm gonna need a master pin for these tracks. Does it just drive in? I know they are salt tracks.
Thanks for all your help.
Clyde
Tue, Aug 21, 2018 10:38 AM
Reply to dogwalkin:
Clyde
The CR4409 is a segment for 6.91" pitch track. It appears you have the conversion set up from 6.75" pitch to 6.91" pitch which the D5's use although a D5H is an elevated sprocket model. Normally the matching chains would be CR2821/2 link numbers. The conversion chain should have alligator master links and be one less link assembly then the 6.75" versions.
Tue, Aug 21, 2018 12:20 PM
dogwalkin
Will the d5h chains be ok?
Tue, Aug 21, 2018 6:01 PM
Reply to dogwalkin:
No, if it is truly D5H track they are 7.5" pitch. If it's regular D5 it's 6.91" pitch.
Tue, Aug 21, 2018 10:38 PM
| Hartley - South Australia
Newby Hall Tractor Fest
