                            in new england those are called Jersey Traffic Barriers as New Jersey was the first DOT to design and use them
Funny...I watch 'Highway Thru Hell' and the Canadians call them 'No Post' rails.
yea--I guess every body calls them something different for sure---when you want zero deflection on a vehicle hit they are cast with holes in the lower "flange" to drive posts thru--every guide rail and traffic barrier has a defined allowable movement--cable barriers being the largest and these being the least aside from a pored concrete wall
Ouch! a little strain on the ole 445 there!
Paso,
I see you even prevailed on Dwight to do the loading. I guess you were the Super. and Tom was the Project Mgr. Good team work never the less. Your 445 would not have left the ground had Deas been in the seat! š
We need a couple of those for a ramp at Vista museum.
JanM
I like to lift heavy items from the end of the loader beams there at the bucket pins.
Paso,
JanM
[quote="janmeermans"]Paso,
JanM[/quote]
Here you go Jan... https://inlandempire.craigslist.org/tls/d/rail/6623006009.html
