The gear are grinding
Showing 1 to 6 of 6 results
Hobo groh
Send a private message to Hobo groh
The gears do not sound good when i try to shift the no 10so bad i can't get into gear any ideas why i think its the transmission brake
Tue, Jul 17, 2018 9:14 AM
oldbeek
Possible the pilot bearing is seized to the input shaft. My clutch brake on an 8t #12 was shot. I didn't want to pull the trans to get to it so I left it inoperable. I grease the pilot religiously Will it start in gear with someone holding the clutch down? If it is stuck discs or stuck pilot bearing that would break it loose.
Tue, Jul 17, 2018 9:53 AM
Pioneernorth
Send a private message to Pioneernorth
Reply to oldbeek:
A good practice on any old school manual transmission is to disengage the clutch and make sure the machine is at a complete stop before shifting out of gear. This will completely stop the trans from spinning. Once stopped even apply brake if needed to keep unit from rolling. Now go ahead and shift to you desired gear.
Tue, Jul 17, 2018 12:21 PM
Hobo groh
Reply to Pioneernorth:
does any one know the cheapest way of repairing this problem and where to start looking for this issiue
Mon, Jul 23, 2018 4:13 AM
Pull the engine and replace pilot bearing on flywheel end of clutch shaft and also clutch brake if needed.
There are modern replacement clutch brake linings that can be opened up and placed around a shaft and then snapped back closed. I don't suppose you could fit something like that through the clutch inspection cover?
Mon, Jul 23, 2018 7:37 AM
Hobo groh
Thanks for the help I'm starting at the brake
Mon, Jul 23, 2018 9:40 AM
oldbeek
Reply to Hobo groh:
Once again!! With it in gear and someone holding the clutch pedal down, will it start or turn over.?? If disc is stuck to flywheel or pilot bound up it will try to move the machine. It will operate with no clutch brake if you are careful when shifting.
Mon, Jul 23, 2018 11:30 AM
Chapter 2 The Link Club's AGM
