1956 model, weight is 21,480 lbs.
Thanks!
Is it a 955H?
Do you know enginemodel?
Where can i find for example how much oil for engine, gearbox etc...
Cant find it at Google...
The 955h is power shift with 330 motor and the 955 serie 12a is standor shift with D315 motor and crankcase oil 5 gal. transmission 4 1/2 gal.,final drive each side 1 3/4,fuel tank 30 gal. cooling systeme 11gal.
So this one is a D315? And its just namned 955?
Horsepowers?
Horsepowers?
[quote="Muttson"]So this one is a D315? And its just namned 955?
Horsepowers?[/quote]
Your 955 nammed 12a serie
Coincides with the change from the HT4 to the 955 12A series in 1955.
Spec sheet from mid 1956.![]()
