Considering a D4D
Considering a D4D
Showing 1 to 10 of 22 results
dead axle
Online
Send a private message to dead axle
Been looking at a late sixties early seventies D4D (sorry I don't have a serial number yet) and was wondering the possible pitfalls of this model tractor. A friend of mine in the business says that they are prone to breaking the cross shaft support areas in the rear housing especially if they have had extreme use in the logging industry. I talked to another guy who was a Caterpillar field man and he was not familiar with that being a common issue. Have any of you seen this or other problems? Thanks in advance for your input.
Sun, Jul 1, 2018 6:32 AM
Thank you received: 40
Hi, Dead Axle.
Wouldn't touch it with a barge pole. TERRIBLE contraptions.
Seriously and just in my humble opinion, pound for pound, the Cat D4 series, with the possible exception of the D4C, is one of the best crawler tractor lines that God ever let anybody burn diesel fuel in. About as close to bulletproof as a small crawler can be.
Sun, Jul 1, 2018 7:30 AM
bursitis
Hi, Dead Axle.
why is the D4C a problem tractor?
Sun, Jul 1, 2018 7:46 AM
DPete
Reply to bursitis:
I bought one from your neck of the woods ( Eugene ) mine is a 66' has wet clutch but dry brakes, not sure when they went to a wet deck but if you plan on lots of hours it would be something to consider. Doesn't really matter for me as it will only see limited use.
1962 D4C
Sun, Jul 1, 2018 8:12 AM
Reply to DPete:
If it's a ex logging tractor check the frame rail flanges for cracks where they attach/bolt to the steering clutch housing. I'm not aware of cross shaft support issues but then a gypo logger can tear up most anything.
Sun, Jul 1, 2018 9:05 AM
Hi, Bursitis.
Around my neck of the woods, they developed a bit of a reputation for over-heating in heavy work and the 'World-renowned' buzz bomb pony motor didn't win them many friends either. There were a good number of them for sale secondhand at the the dealers shortly after the D4D came out.
Sun, Jul 1, 2018 9:23 AM
d4c24a
Hi, Bursitis.
Factory direct start , still going strong since 1962 , main thing to look out for is where the saddle bolts to the block for the equaliser spring as it can break out the bolt holes , i also have a D4D7R that has just had an engine transplant and should be up and running soon
Sun, Jul 1, 2018 3:07 PM
Glum
Reply to d4c24a:
Are those outboard mounted carrier rollers an LGP thing or a common conversion over in Europe?
Sun, Jul 1, 2018 5:26 PM
d4c24a
Reply to Glum:
i think it was a change of design as i have seen them on standard track too , not just lgp ?
Sun, Jul 1, 2018 6:08 PM
dead axle
Online
Reply to d4c24a:
Thank you all for your input, pictures and advice.
Sun, Jul 1, 2018 6:20 PM
bursitis
Reply to dead axle:
what year or serial number did the D4 get oil clutch and steering clutches? i used a D4H probably in 95 or so and really liked it. i see quite a few reasonably priced D4H around. why are they so cheap? was there something wrong with them?
Sun, Jul 1, 2018 7:32 PM
