D7G dead axle question
Showing 1 to 10 of 13 results
DWC7
Send a private message to DWC7
The nut out on the end was stripped off. Sometimes I’ve seen just the nut be bad but the reads on my axle are rounded pretty bad. Anybody had any luck with a bush fix for this short of replacing the dead axle.
Sun, Jun 24, 2018 11:53 PM
"how in the world did that happen?????"
Mon, Jun 25, 2018 2:12 AM
DWC7
Idk but it’s dissaponting!
Mon, Jun 25, 2018 6:42 AM
WA7OPY
Send a private message to WA7OPY
Reply to DWC7:
You don't need to get a new axel, the threads can be restored on the old one in a machine shop....WA7OPY
Mon, Jun 25, 2018 6:56 AM
DWC7
Reply to WA7OPY:
Yep that was what I meant. I was just hoping I didn’t have to tear it that far down if I could keep from it.
Mon, Jun 25, 2018 8:30 AM
Reply to DWC7:
do you think a new nut and locktite would work, and/or a spot weld on the end?
Mon, Jun 25, 2018 8:48 AM
DWC7
Reply to dpendzic:
I thought about building it back up and try to chase new threads on it.
Mon, Jun 25, 2018 9:29 AM
WA7OPY
Reply to DWC7:
I would not do that, the shafts are a high alloy steel. Without the right preheat and welding the shaft with brake off. The chances of getting it ground round and threaded are slight. If the new nut will not fix the problem, pull the axle and make friend with the machinist. My 2 cents....WA7OPY
Mon, Jun 25, 2018 9:51 PM
DWC7
Reply to WA7OPY:
Was trying to keep form pulling axle and having to press off gears.
Mon, Jun 25, 2018 11:27 PM
Billy-
Send a private message to Billy-
Reply to DWC7:
ITR make a good quality aftermarket dead axle for these tractors at a realistic price. That thread has a big job to do. Issue is if the thread fails and the outer bearing hub comes loose on the shaft then its likely to ruin the shaft and bearing holder anyway.
Although if your threads are buggered on the axle then removing it maybe a challenge using the cat pullers.
Tue, Jun 26, 2018 5:52 AM
d9gdon
Reply to Billy-:
You can get a new 2S-7062 aftermarket dead shaft in Dallas for $600, or you could get Holt out there with their mobile machine shop for $15-18 thousand.
Tue, Jun 26, 2018 6:59 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
