Thinking about swapping shoes
Christopher
Send a private message to Christopher
I wonder if the undercarriage from my D4-7U would work on my 2T. I think this will be one of my next endeavors. I'm fixing to start tearing down the two units anyway so might as well play a little. The under carriage under my 2t looks rough. Plus whoever had it in the past stole the blade and hydraulics off of it. My 7U has an adjustable blade that looks to be in good shape and the bottom end doesn't look too bad.
Sun, Jun 10, 2018 6:33 AM
Mike Meyer
My understanding is they interchange, I've just fitted D4D bottom rollers to my old RD4 without any drama's.
Mike
Sun, Jun 10, 2018 7:22 AM
OzDozer
Reply to Mike Meyer:
Mike
All the D4's and RD-4's use 6.75" pitch track links, from the very start of RD-4 production. However, there are at least 6 different track link P/No's.
Basically, the variations between the 6 different links, are in track link height and wear limits, and in track shoe bolt diameter.
With each progressively-improved track link, the link height increased, the hardening depth increased, and the bolt diameter increased.
In order of P/No sequence, the links P/No's and specifications are;
P/No .......... Height ...... Bolt Dia. ..... Hardening depth to Rc 45 ...... Replacement height limit
6B4645 ...... 3.53" .......... 1/2" ...................... .000" ................................. 3.15"
4K7039 ...... 3.66" .......... 1/2" ...................... .130" ................................. 3.25"
4K6647 ...... 3.66" ......... 9/16" ..................... .130" ................................. 3.25"
5K9423 ...... 3.66" .......... 1/2" ...................... .260" ................................. 3.25"
5K9457 ...... 3.66" ......... 9/16" ..................... .260" ................................. 3.25"
7K1825 ...... 3.75" ......... 9/16" ..................... .260" ................................. 3.40"
Information is from the CTS handbook dated January 1970.
Note: the link P/No's are consecutive for RH and LH links.
Mon, Jun 11, 2018 8:36 AM
Christopher
Reply to OzDozer:
Actually, what I was talking about swapping everything from the final drive on.
Tue, Jun 12, 2018 7:40 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
