Grader model?
Grader model?
Showing 1 to 10 of 19 results
ETD66SS
Send a private message to ETD66SS
Since the other CL ad for a CAT grader was a scam, I'm turning my attention to this one: https://buffalo.craigslist.org/hvo/d/grader/6598722788.html
Is that a 112? I've asked the seller for the serial number. Why someone would post an ad and not include the serial number is beyond me.
One thing with that grader is, I see a lot of HYD control levers, but I also see a lot of drive shafts... Were HYD motors used to actuate gearboxes & drive shafts as opposed to HYD cylinders way back when?
Wed, May 30, 2018 5:05 PM
Thank you received: 23
Which picture are you seeing all these hydraulic levers in? I'm no expert : ) but I'm only seeing dog clutch levers in two pictures of the inside of the cab; images 9 and 12 - like about 6 or so of them adjacent to the steering wheel. I do seem some power steering hoses but that's about it.
Wed, May 30, 2018 6:29 PM
ETD66SS
I guess that's what they are, never used anything like that...
Wed, May 30, 2018 7:20 PM
I think you are correct in guessing a 112 from the early 1960's .....possibly as early as 1959 (112E produced from 1959-1961)
I see a 4 cylinder D330 looking engine and a knuckle buster type control. Not a 212 because CAT stopped production of the smallest grader in 1957 here in the USA.
In the larger grader, I think the 12E (99E series here in the USA) was the last dog clutch type control produced from 1959 through 1965. Maybe the 112F produced 1960 through 68 was still a manual control?????
Anyway it looks like it has had a very nice paint job. Whether the grader underneath is tight or worn out should be easy to determine by inspection in person. With all knuckle buster control machines a good test is to try to lift the front wheels off the ground by pressing the blade down.
Wed, May 30, 2018 7:56 PM
bursitis
could be the seller is a grade A collector who has totally restored the machine to as new specs. you can tell by the fact it has no oil leaks and he has paid special attn to the detail of painting the gear case and bolt beads black. "WINK"
Wed, May 30, 2018 8:28 PM
oldbeek
Reply to bursitis:
Hydraulic blade slide was standard clear back to 1950. Very complete but pricy for a hobby machine. Gear boxes could be completely worn out. Hours??
Wed, May 30, 2018 9:34 PM
Hobo groh
Send a private message to Hobo groh
Reply to oldbeek:
i think it can be a 112 because there is no muffler like the d2
Thu, May 31, 2018 4:27 AM
ETD66SS
Reply to Hobo groh:
Ok, so the seller got back to me and sent me some more pictures.
[attachment=49054]IMG_5540.jpg[/attachment][attachment=49055]IMG_5542.jpg[/attachment][attachment=49056]IMG_5556.jpg[/attachment][attachment=49057]IMG_5558.jpg[/attachment]
Seller says he's willing to work with the price.
Can anyone tell me what year this is? It's a 112E? I hear these are difficult to find parts for?
I would use it for building/maintaining driveways on my 60+ acres of land. Nothing too heavy.
I should NOT be buying another toy such as this...
Sat, Jun 2, 2018 7:00 AM
josh
Thank you received: 6
Reply to ETD66SS:
112E, 1964, 85hp, 21,200 lbs.
Missing the Scarifier,
If it were me, I would look around for an #12 8T or such, close to the same weight, but more power and should be half the price, for that price I'd be looking for a real nice late model 212.
Sat, Jun 2, 2018 9:22 AM
catskinner
Reply to josh:
That grader is a 112E and a 1966 year. 91G 412 by my Cat book. catskinner
Sun, Jun 3, 2018 9:12 AM
catskinner
Reply to catskinner:
There is NO hyd. hoses on that grader. That is CATs power steering on the front of the grader. Front tires are on backwards. Turn the outer single levers, on the control box,so they lean back towards the operator, as those are the lift levers for the ends of the blade and those are the two levers that you use the most. With them back, you don't have to reach so far forward. That's a nice looking grader. Don't go with a 212. catskinner
Sun, Jun 3, 2018 9:28 AM
