cat sixty scraper size
Showing 1 to 10 of 21 results
mog5858
Online
well guys looking for a little info on what size of a scraper you can pull with a sixty. i have a R.G power control to go on the back of my sixty but then i going to need something to hook it up too? size or model of scraper that work well ? i was thinking a Cat #60 but that's too new and well most around her have been hack up by farmers adding hydraulics to them. looking to be in the 1925-30 rage for the look of my setup.
Wed, May 23, 2018 7:39 PM
bursitis
probably need to be a letourneau
Wed, May 23, 2018 7:48 PM
Thank you received: 23
Reply to bursitis:
I have a related question for the knowledgeable. Could one predict the size of a #20 scraper i.e. something that's the same basic design as a 40 or 60 but intended for a D2, based on a relationship between the D4's weight and hp and the 40 cutting width and bowl size?
I'm just curious if a scaled down version could be made that would actually be a good match for the D2
Thu, May 24, 2018 6:21 AM
Chuck C
Neil, there are several different makes of two to four yard scrapers the a D2 will handle. Ashland, Beckley(spelling?) and the LaPlant Choate that I have . I have found several in recent years on Craigs List, just have to keep looking. If someone gave me $10000 I would sell my La plant Choate. The Ashlands and Beckleys usually go from $3000 to $6000. Took me 5 years to find my LaPlant Choate and another year to restore it. the second picture I think is a Beckley
Chuck C
Thu, May 24, 2018 7:33 AM
Reply to Chuck C:
Chuck C
Hi Chuck,
I definitely wouldn't say no to one of those scrapers but I was more asking about duplicating the #40 design on a smaller scale for the D2. I just like the way those 40s and 60s (and I guess all the Cat towed scrapers) look - the design speaks to me! : )
Thu, May 24, 2018 8:03 PM
bursitis
[quote="Neil"]I have a related question for the knowledgeable. Could one predict the size of a #20 scraper i.e. something that's the same basic design as a 40 or 60 but intended for a D2, based on a relationship between the D4's weight and hp and the 40 cutting width and bowl size?
I'm just curious if a scaled down version could be made that would actually be a good match for the D2[/quote]
I have a Murray that is sized for a D2. it is hydraulic but uses a cable to lift the apron. looks to be based on a letourneau.
Thu, May 24, 2018 8:06 PM
mog5858
Online
Reply to bursitis:
dose any one know if there are Hp - yards calculation? only info i found was for a LS letourneau witch is 8 yard struck and 11 heaped dose that not seem like a lot for a sixty ? how dose one size a scraper to the cat?
Neil the #40 was Caterpillars first Hyd scarper it never came in a cable control i am not sure if they made a CC for a 4 that was double drum. i only know of the single drum one that letourneau made to run the blade from over head stacked on top of the towing winch.
forgot to add pic
Mon, May 28, 2018 9:24 AM
Reply to mog5858:
forgot to add pic
I guess a #27 or such could be grafted on to the back of a D2 but it would look cooler if it was a #22 : ) and sized accordingly. Cable control rules!
I reckon the way to go Martin, would be to measure the cutting edge width for the #40, #60, #70, #80, and work out the rough hp/weight of the tractor to the edge width. I think the struck / heaped capacity could also be checked the same way but I think the critical item is the cutting edge width because the tractor needs to be able to pull it with the bowl down. Those other scrapers the guys listed above would be a good sanity check that the calculation came out right.
Chuck and Bursitis: would you fellows be so kind as to measure your cutting edge widths and struck/heaped capacities?
Mon, May 28, 2018 7:19 PM
JoeG
Send a private message to JoeG
This is an 8 yard struck 12 yard heaped Bucyrus Erie S90 behind my D6 9U and it is all the machine wants by itself to get a 2/3 to 3/4 load (estimated) with a decent cutting edge, not perfect and not shined up yet either. I can push load it pretty good with the D4 but not a 12 yard load (again my estimate) and once loaded it will haul in 3rd and dump/spread in 2nd but a slightly smaller unit would probably be a better fit.
I don't know as much about the 60 but that should give you something to go by at least, I would opt for a smaller scraper as they are easier to load and more fun to operate without being so hard on the tractor. I had to do a head gasket job on mine once I started running it, scraper gives it a real workout.
Tue, May 29, 2018 12:34 AM
mog5858
Online
Reply to JoeG:
thanks for the pics and your input that helps. i found a nice little scraper but it's not as wide as a sixty. i know that not a big deal just trying to get things mach up as i like to make sure she can work for her lunch.
Wed, May 30, 2018 6:59 AM
old-iron-habit
Reply to mog5858:
forgot to add pic
[quote="mog5858"]dose any one know if there are Hp - yards calculation? only info i found was for a LS letourneau witch is 8 yard struck and 11 heaped dose that not seem like a lot for a sixty ? how dose one size a scraper to the cat?
forgot to add pic[/quote]
I have the Letourneau LS that I ran some starting when I was 15 years old. (Holy crap, 50 years ago this summer) It was behind a 3T-D7 and that 3T needed a push from the 2U in the hard clay ground to get a heaped bowl. Takes a lot to pull that cutting edge thru hard ground.
Wed, May 30, 2018 9:13 AM
Price Tractor Pull
Price Tractor Pull
