12E Grader power control unit clutches
Showing 1 to 9 of 9 results
gggsam
Send a private message to gggsam
Hello all,
It's time for some work on the power control unit on a 12E grader S/N 99e9701. The blade lift (both sides) and circle reverse controls are very worn - quickly learning about the "knuckle buster" nickname.
A couple of questions for the experts -
1. If I am replacing parts, is it just the clutches? Or springs too? Anything else that wears?
2. Does anyone know the part number for the clutches? I have a parts book, but not sure I am reading it right.
Any help is much appreciated.
Sam
Fri, May 18, 2018 8:47 AM
Thank you received: 19
I'm guessing Deas Plant will respond on this thread so I have a question regarding Sam's unit that might be helpful, which is:
- can the clutch dogs be refurbished to restore original function i.e. machined to present fresh engagement faces that make engagement reliable and not be prone to popping out? ( I realize they can be swapped to other positions to present the opposite unworn face, but if this has already been done, can the dogs be usefully refurbished?)
- how much of a clean engagement surface is required? This question pertains to trying to minimize the amount of material to be machined from the clutch faces
Fri, May 18, 2018 7:19 PM
bursitis
[quote="Neil"]I'm guessing Deas Plant will respond on this thread so I have a question regarding Sam's unit that might be helpful, which is:
- how much of a clean engagement surface is required? This question pertains to trying to minimize the amount of material to be machined from the clutch faces[/quote]
i rebuilt a box many years ago and resurfaced the wear areas on the dogs. it did improve the function"a little".
Fri, May 18, 2018 7:37 PM
Thank you received: 23
Reply to bursitis:
Hi, gggsam and Neil.
Here 'tis:
http://www.acmoc.org/bb/showthread.php?20409-Cat-12-Graders-Pre-G-series
Please feel free to fire away with any unanswered 'kwestyuns'.
Fri, May 18, 2018 8:46 PM
The clutch dogs are 6 each 2d8669 on the rear and 2d8670 toward the front. Of course you would also have gears 4d1795 x 10 and 2 special 4d1794 duplex gears with mating dogs. I am guessing the gears might be harder than the dog clutches???
Might need some 2d365 springs to center the clutch levers in the neutral position
Sat, May 19, 2018 2:03 AM
From Deas' post, the next time someone has an as-new condition face in hand, could s/he measure the profile dimensions so it can be posted here and then it's available for folks that want to refurbish
Sat, May 19, 2018 2:11 AM
Wombat
Donor
years ago when I had a 17K 12E, purchased 2nd hand and flogged out, I rebuilt much of it including the dog clutches. I rebuilt them with low hydrogen welding rods and trimmed them with a 4" angle grinder. They worked exceptionally well, could lift a tandem off the ground with not a lot of pressure on the blade lift control lever. When they started to crack too much up the bush, I would back up a steep bank, pull the front off the control box and swap from left to right etc. When next near the work shop would rebuild them again. I generally got about 18 months work out of one side of them. For me this was a cheap and easy fix.
Wombat
Sat, May 19, 2018 4:17 AM
gggsam
Reply to Wombat:
Wombat
Thanks all. That is very helpful.
Sam
Mon, May 21, 2018 7:37 AM
oldbeek
Reply to gggsam:
Sam
Did you note the part in Dease explanation about the hi-lift gear case. Check the wear in those gears first. If they are warn and give huge resistance the clutches will kick out. Same goes for the circle wear/ adjustment and lack of lubrication will cause kicking. Do the keyways in the lift shafts look like they have been used?
Tue, May 22, 2018 10:01 AM
Reply to oldbeek:
Hi, Folks.
Another wear factor that many people don't consider is the wear in the worm gear bearings below the blade lift gear. This is adjustable as per the instructions in the maintenance guide in the link that I posted earlier.
Re rebuilding the wear faces on the dog clutches, these dog clutches were hardened at the time of the manufacture after they had been machined. They would last for YEARS before needing any attention. Re-machining will take away some of that hardened material so that the re-machined faces will likely not last as long. For a machine that is only doing a few hours per year, this will likely not be a problem.
If you choose to rebuild them yourself and grind them back to shape, try to have a dog clutch with unworn opposing faces to match your handiwork up to as a guide.
Mon, Oct 29, 2018 8:44 PM
| Hartley - South Australia
