D4 undercarriage
D4 undercarriage
Showing 1 to 10 of 15 results
EL300B
Send a private message to EL300B
I have a 1960 D4C 40A that needs an undercarrige bad.I bought a 7U carcass that is missing the motor,fuel tank and tinware,but has a very good 5 roller undercarriage.I know the tracks and rollers will interchange but will the sprockets interchange?And can I just trade track frames? Thanks
Sun, May 13, 2018 7:10 PM
The only thing that is the same is the 6.75" pitch.
D4 bushing diameter is 2.0", the D4C 2-1/8" diameter.
D4 sprockets are 27 tooth, The D4C is 29.
The pitch diameter is also different, 29.2" on the D4, 31.33" on the D4C.
D4 grouser bolting is 1/2", the D4C is 9/16".
Sun, May 13, 2018 10:50 PM
EL300B
Thank you for the information.I did'nt know there was that much difference in the tracks.Will they work?Also what is the "pitch diameter".I assumed that if the pitch and width was right I'd be fine.Worse come to worse I may have a very good 7U undercarriage for sale.Thanks again
Mon, May 14, 2018 3:16 AM
Thank you received: 30
Reply to EL300B:
I would be interested in the complete 7U undercarriage should you decide to sell it. I’m wanting to make my orchard model into a 5 roller machine. Thanks. JM
Mon, May 14, 2018 3:35 AM
Pitch diameter is basically how tall the sprocket is. Going from a 29 tooth down to a 27 tooth with the pitch remaining the same 6.75" results in a smaller sprocket.
The D2's have a relatively small sprocket compared to most other tractors. Sort of gives a rocking horse appearance if you look from the side. They also have the track frame pivot shaft in front of the sprocket so that may be one reason it was done that way. In general most improvements to the track systems from the early years result in more track on the ground and improved stability vs less track on the ground and easy turning the original designs had.
Mon, May 14, 2018 3:40 AM
Sprocket pitch diameter is the centerline diameter of the track/rails as they wrap the sprocket.
Sprocket tip diameter for the D4 is 30.19", the D4C is 31.74"
Mon, May 14, 2018 5:13 AM
Check your sprocket part number on the D4C. Apparently there are both 2" diameter and 2-1/8" diameter bushing versions used.
Mon, May 14, 2018 9:12 AM
EL300B
Thanks,I'll do that.This is a very early D4C serial 3xx,not sure exact,but before serial 400.
Mon, May 14, 2018 9:50 AM
Reply to EL300B:
It would be unusual that it would still have the original undercarriage tracks/sprockets.
Mon, May 14, 2018 10:25 AM
Also note part number if it has a weld on sprocket rim.
Mon, May 14, 2018 9:31 PM
EL300B
Sprocket part no. 1M1721 Does not have a weld on rim.35 track links.I've owned it 40 years and have never touched the undercarriage or drive train.Tried to read the hour meter but the glass was frosted.Is it possible to weld the 7u sprocket rim on the 4C?? Thanks
Tue, May 15, 2018 7:13 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
