Tool bar blade for D6 9U
Showing 1 to 6 of 6 results
TomTrack44
Send a private message to TomTrack44
Been looking since last September, finally found one! I saw what looked like a "Cat" toolbar blade on an HD11 that was for sale, with or without the blade,called and asked about it, "maybe not that one but what do you need?" Looking for a cat tool bar blade for a D6 9U, serial # 23134! Let me check and I will call you back. They had one in the yard, I am going to pick it up Wedensday! Anyone know the weight including the plates that go to the track rails? thank you, Tom
Sun, May 13, 2018 2:21 AM
Casey Root
Might try this guy. The tractor has been listed for quite some time. Maybe they will separate the two.
https://www.machinerytrader.com/listings/construction-equipment/for-sale/11843645/1956-cat-d6
Sun, May 13, 2018 2:46 AM
Thank you received: 19
Reply to Casey Root:
I've got the parts manual but they don't give the weights.
Sun, May 13, 2018 6:09 AM
Thank you received: 85
That’s great that you found a toolbar dozer for your new acquisition. I’d love to see it when it’s installed.
Are you using it with a CAT hydraulic system or aftermarket? I’d like to set one of my 9U’s up with the same combination, but mainly for the toolbar beam for Ag work.
Sun, May 13, 2018 11:38 PM
josh
Thank you received: 6
From 1956 price list, #6 Tool Bar Bulldozer Blade Arrangement, including draft members and trunnion group, hydraulic cylinders and bulldozer blade, does not include hydraulic control. weight of unit 3075 lbs, shipping weight 3265 lbs. Price $1320.00
Mon, May 14, 2018 3:14 AM
Crawler Dollars
Reply to josh:
$1320 in 1956 = $12,110.71 in 2018
Mon, May 14, 2018 4:36 AM
Reply to Crawler Dollars:
I priced a toolbar group from Peterson CAT back in the 80’s or 90’s??? It was every bit of $10k then.
Mon, May 14, 2018 5:12 AM
Price Tractor Pull
Price Tractor Pull
