D8 progress
D8 progress
Showing 1 to 10 of 14 results
AHINKLE
Send a private message to AHINKLE
Well I finally have the main case ready for sandblasting. Its a good feeling to finally have the machine completely dismantled and ready for reassembly...
Thu, Apr 24, 2008 9:35 AM
Thank you received: 60
Seeing the bare bones case reminds me of a question I've had for some time so maybe now is a good time to ask.
Does anyone know what type of product, paint, glyptal or whatever Cat used as the sealer for the cast iron......that kinda mustard color yellow stuff???? on the inside of the cases.
Sat, Apr 26, 2008 11:50 AM
8C 361
Thank you received: 12
I always thought that undercoat was similar to Rustoleum clean metal primer.
Sat, Apr 26, 2008 3:41 PM
OldNuc
Send a private message to OldNuc
Reply to 8C 361:
Hard to tell without a good chip sample to test but one of the favorites from times past was zinc chromate. It does have an odd mustard yellow color. The zinc chromate has been on the environmental No-NO list for a very long time.
Sat, Apr 26, 2008 8:18 PM
Reply to OldNuc:
I'm pretty familiar with the Zinc Chromate primer as a bonding agent (was the standard Navy primer on aluminum superstructure) but I never thought of it as a sealer in an oil soaked environment.
Sat, Apr 26, 2008 10:11 PM
8C 361
That is what that Rustoleum product I mentioned was, Zinc Chromate,
I have no idea if it is still available.
Sun, Apr 27, 2008 3:22 AM
OldNuc
Reply to 8C 361:
The USN did indeed use it on all aluminum to iron connections. The rest of the aluminum was polished. Remember: shine she must, run she might.
True oil based zinc chromate is a thing of the past.
The insides of the cases were painted when thy we still squeaky clean. I can not remember what we used inside of engines and Harley cases but it was nothing special. Just some linseed oil based paint.
Sun, Apr 27, 2008 11:52 AM
alan627b
Send a private message to alan627b
Reply to OldNuc:
I have heard the name Glyptol used before, I think it's normally used as an electrical component case paint. Seems I've heard it used in car magazines, when painting lifter valleys and the inside of engine blocks.
Hope this helps,
alan627b
Sun, Apr 27, 2008 11:23 PM
John from Fresno
Reply to alan627b:
Hope this helps,
alan627b
Most transmission and transfer cases in trucks back then were coated with Rustoleum "Red Lead" to prevent the cast from weeping and seal the pores so the oil would run back to the bottom of the case. It was my understanding that the Rustoleum rusty metal primer was the same back then. It has to be brushed on from the can. I think they must have done that prior to any machining. And I am sure they were dipped in hot paint. After sandbalsting, I always give a good washing with gasoline to remove any sandblasting dust left behind.
John
Mon, Apr 28, 2008 4:37 AM
SSsssteamer
Send a private message to SSsssteamer
Reply to John from Fresno:
John
Starting 1965, I worked for Skagit Corporation in their transmission department for 5 years. We built sub assemblies that were gear boxes, hydraulics, and so forth. After the gear boxes were cast in our foundry, they were put out in the yard in the weather for about a month or so; to age which releaved stresses. After the metal had setteled in, it was taken to the paint shop for the quick spray of red lead primer to the exposed surfaces. If they were ready for it in the machine shop, after debur, it was then machined to the blue print specifications, otherwise it was held in storage until it was needed. After machining, the housings came to our transmission department. Using the needle gun and die grinders, we removed all of the scale, sand deposits, casting flash, and so forth. Bores were honed to fit their Timken bearings, shavings were dug out of their tapped holes, and gasket surfaces were smooth out where the taps had pulled metal up. After a good solvent and air hose cleaning, we sealed the inside of the cases with a red lead colored transmission sealer made by the Preservative Paint Company. All though it might have been just an oil base paint, it was thinned with Lacquer. This sealer was only used on the insde of housings that the outside finish coat would never see. After brushing it on, it took about 3 hours to dry and it did a wonderful job of sealing in holes and other places where oil might escape. But where it was most important, is that it prevented any missed scale, sand or other debris from getting loose from the casting and getting in to the beaings. We finished our assembling and often mounted our transmissions on running test stands to check them for heat build up. Our equipment was built to all sizes. Many of the gear boxes we built were as big as the gear boxes used in a D-9. My title there was Jouneyman Assemblyman. From an internet gear box site they stated: "...the interior of gear housings should be painted with white epoxy sealer to provide a hard smooth surface that is easy to clean, seals porosity and seals in debris like casting sand. All components for assembly should be properly stored in a dry area prior to assembly. All gears and bearings should be covered, and bearings should be stored on their sides. " The most fascinating thing that I learned while working at Skagit was: the huge amount of fuzz left from our shop rags, contaminated the gear box enough to plug an oil filter. On government contracts we were required to filter all of the oil while running-in the gear boxes. That is where the clear oil filter quickly tells you, what you have in your oil. i.e. Shop rag fuzz, metal filings, scale etc.
Mon, Apr 28, 2008 6:53 AM
Art From De Leon
Send a private message to Art From De Leon
Reply to alan627b:
Hope this helps,
alan627b
[quote="alan627b"]I have heard the name Glyptol used before, I think it's normally used as an electrical component case paint. Seems I've heard it used in car magazines, when painting lifter valleys and the inside of engine blocks.
Hope this helps,
alan627b[/quote]
The EASTWOOD COMPANY carries it.
Here is a short discussion about its 'benefits'.
http://www.hotrodders.com/forum/eastwood-glyptol-sealant-6777.html
Mon, Apr 28, 2008 8:36 AM
