D2 PTO Driven Hydraulic Pump Adaptor - Aftermartket Piece???
Showing 1 to 9 of 9 results
Sasquatch
So while I was at the big swap meet this last weekend I saw this bolt-on hydraulic pump adaptor riding around in the back of a golf cart and took a few minutes to look it over and get a couple of pics. We were able to verify that it bolts directly to a D2 PTO housing and is driven by the PTO shaft - it appears to be geared up a bit faster on the pump end, but the pump looks rather small compared to the Cat equivalents of the day. The housing itself did not look to have a Cat type casting number on it either. My question is, does anybody recognize this unit? And if so, what did it provide hydraulic power for? Being mounted to the rear PTO it wouldn't be live power, so I'm really curious about this setup. Any ideas?
Tue, May 1, 2018 8:58 AM
Thank you received: 20
Can't say that I've seen that exact version but looks like it is probably a 2:1 speed increaser which would allow a higher speed smaller pump to put out a higher volume and possibly higher pressure. Application could be just about anything requiring hydraulic drive. Meets the challenge of a high volume output without a monster pump like you would need to match say a #44 unit.
Tue, May 1, 2018 10:17 AM
josh
Thank you received: 8
I have one of those units, one nice thing is it uses those readily available hydraulic pumps.
Tue, May 1, 2018 10:24 AM
Thank you received: 24
Reply to josh:
What is the brand and model # Josh?
Tue, May 1, 2018 9:08 PM
josh
Pump brand is Unknown, gear ratio on the drive is 35 to 15, input shaft is 3/4" keyed, mount appears to be standard, pump numbers in picture.
Tue, May 1, 2018 11:35 PM
Sasquatch
Reply to josh:
OM, josh - thank you for the information 👍
Wed, May 2, 2018 12:24 AM
Reply to Sasquatch:
Apologies Josh, I meant the brand and model of the reduction unit.
Wed, May 2, 2018 1:34 AM
josh
Other than a decal that says something about oil level and type, cant make it out, there is nothing on the unit, no casting numbers or anything else.
Wed, May 2, 2018 6:05 AM
old-iron-habit
Reply to josh:
Sasquatch, Did you bring it home? Looks like a sweet little unit.
Wed, May 2, 2018 9:00 AM
Sasquatch
Reply to old-iron-habit:
I was able to find a series of numbers stamped into the exterior of the case that resembled a casting number or other I.D. but no manufacturer name or tag. They weren't stamped very deep, unfortunately I didn't take a close up picture of them.
o-I-h, no I didn't bring this unit home as it was already being carried by its new owner - it is an interesting piece for sure.
Wed, May 2, 2018 10:07 AM
