Reply to WyoCat:
I would bet money on the PT 3889 tractor being the one set up as a high TEN. I would be curious to know if this is the case. If you could let us know I would appreciate it! Have a great day!
PT3889 is the one that when you spin the Transmission input shaft clockwise and go through all 4 gears the clutches spin backwards in 3 gear selections.
Which with a Bull gear in the final drive would make the track axle go forward.
Wouldn't this be correct for a standard?
WyoCat how would you know that is the transmission case that was setup for a high ten just by the serial number?
I made a mistake on the other transmission case its PT4501 not PT4509.
If it makes a difference at this point.
Actually before I hit send, I am still confused about the direction of input verses the direction of axle movement?
Because if you face your watch/clock and "start" it in a CW direction. Then walk around back of the watch/clock it now looks like it running CCW. Which would be the input to the transmission which would be operators perspective, hence Input is CCW.
Engine- CW from front because you put the crank in and pull up in a clockwise motion? Yes or No??
Tranny input - operators perspective would then be CCW
Tranny ouput pinion-would then be CW
Ring gear-direction thru clutches would need to be CCW
Final drive bull gear-would be CW
So it would have to be the left ring gear is correct which means 3889 is a Standard???
