D7E 47A direct drive
DWC7
Send a private message to DWC7
What are the fluids spec'd for this machine.
Mainly the tranny and clutch housing is what i need to know, and if their is anything else.
The engine ill just use 15w-40 the finals ill use 90w.
I dont have a operators manual and the service manual doesn't say.
Thanks for your help.
Fri, Apr 27, 2018 2:21 AM
gemdozer
Thank you received: 12
The operator manual pages 7 the oil is SAE 30 for cluch housing and transmission
Fri, Apr 27, 2018 4:21 AM
Thank you received: 19
Reply to gemdozer:
Current recommendation would be TO-4 spec 30wt TDTO for anything with clutches.
Fri, Apr 27, 2018 4:33 AM
DWC7
Reply to gemdozer:
Thanks i dont have a operators manual
Fri, Apr 27, 2018 4:50 AM
seiscat
Reply to DWC7:
Hi DW7, Here are the original specs from the Operation and Maintenance Instructions.
[attachment=48352]D7E 47A capacities.jpg[/attachment]
Craig
Fri, Apr 27, 2018 5:00 AM
DWC7
Reply to seiscat:
Craig
[quote="seiscat"]Hi DW7, Here are the original specs from the Operation and Maintenance Instructions.
Craig[/quote]
Thanks for the info
Sat, Apr 28, 2018 3:14 AM
