What to do to clean the water passages in a rusty block?? d4400
Showing 1 to 10 of 10 results
WA7OPY
Send a private message to WA7OPY
Well I have the head back on, the rusty gears changed in the front housing, rockers are rebuilt and the valves are set. Now I need to clean some of the rust from the water passages in the block. When I pulled the number 3 liner there was a lot of loose rust dust in there. I cleaned the head inside the water jacket when it was in the parts washer, but the block is a different story . Its still in the cat, and most of the engine is put back together. My guess there is one or two handfuls of loose rust caught in the water jacket around the liners I didn't remove . I was thinking about making a plate to cover where the water pump sits and making one other plate that I could hook up a hose where the lower water line goes to the rad. I would then blow compressed air in the water drain and let the dust blow out from the hose away from cat, maybe under the door and outside. The engine must have been used with water only and no antifreeze to make the rust dust that's in there. Then I would flush the works out with clean water or maybe rig up a water pump and pump Metal Rescue® around and around to remove the stuck stuff. Right now the block is bone dry and I think a lot will blow out. I will rebuid the water pump and the rad will get reworked although it looks real good. Does anyone have tricks that will remove the rust dust ect from the water jackets? Anyone used Metal Rescue®? Thanks ....WA7OPY
Thu, Apr 12, 2018 9:40 AM
Mike Meyer
Using a acid is the best way, I use Citric Acid which is just a food preservative and it is brilliant though works best in warmer conditions and over several days, Cat sell 2 acid cleaners, one is a fast acting acid that requires a flush after several hours, the other I suspect is Citric Acid as they say to leave it in the system for several days before flushing. Use half a cup of a good dishwasher powder in the water for the final clean, that will remove any old oil and grease too.
Mike
Thu, Apr 12, 2018 11:10 AM
Reply to Mike Meyer:
Mike
While various chemical treatments will remove some rust and scale they do little to attack the heavy deposits that build up in the lower cooling section of the block.
Thu, Apr 12, 2018 12:40 PM
OzDozer
If you have slabs of hard scale, the only thing that removes that, is physically breaking them up, and pressure washing or blowing them out with compressed air.
A solution of 3-4% hydrochloric (muriatic) acid, left in the cooling system for a few hours will remove a lot of corrosion.
However, this acid is no respecter of already-thin metal, or non-ferrous metals in the system - and it attacks good metal as well - so you use it with great care, and with plenty of personal skin and eye protection.
Thu, Apr 12, 2018 5:38 PM
Not much you can do about it at this point, but the seals at the base of the undisturbed cylinder sleeves may be dried out and cracking. A thorough cleaning may just mean there is nothing left that might collect around the seals and stop/slow the leaks. Still need to flush it out if you can but don't be surprised.
I had that happen when I flushed water in the block drain hole during a radiator cleaning. Went from a tight cooling system which had never leaked to a leak so fast I could watch the level of water dropping in the radiator neck! In the end i was able to use a radiator stopleak product to replace the sediment and rust i had washed away from the base of the liners. After that treatment and an oil change, the tractor ran well and stayed leak free for a couple years. When it started getting moisture in the engine crankcase again I assumed it was the seals leaking again but in the end I discovered a rusted out freeze/casting core plug under the valve cover on the head.
Thu, Apr 12, 2018 6:52 PM
WA7OPY
Ok the liner I pulled out had good newer o rings on it, and there was no signs that there was a leak in the liner seals. I would have to think all the liners were fit at the same time with new seals as thay all had the same wear( not much if any.) I am a little afraid of acid , I don't want to remove the rust around the liner seals or I might have a water problem. I think I will go with air and then a good water flush
Fri, Apr 13, 2018 6:37 AM
Mike Meyer
Reply to WA7OPY:
Just remember that lower water passage between the main motor and the pilot motor is very small, as are the water passages in the pilot motor itself, and it is very easy to choke them with simply swirling crud around. Citric Acid is very benign, you probably drink it every day as it is used in most sodas as a preservative and I use it a lot on my old Cats, I remember helping my Mum as a kid make lemon cordial with both citric and tartaric acids as ingredients, I don't even use gloves even when handling the citric acid powder though my hands are pretty tough, in fact I have some citric acid solution in my RD4 engine right now that I'm about to fire up after breakfast and get discing with that tractor, use about a cup of citric acid powder dissolved in a bucket of hot water, then add cold water to fill the system, you will be amazed at how that acid just dissolves old rust away but it will take up to a week in cold weather.
I'd think about removing your pilot motor heads before cleaning because that will allow you to blow water and air to back flush through the system, plus better clean the pilot motor cooling passages, you can re-use the pilot head gaskets.
Mike
Sat, Apr 14, 2018 3:20 AM
WA7OPY
Mike
Thanks I didn't think about the pony engine, It could be a bad deal if I drove the crud into there. I think I will remove the pony heads and make 2 plates to fit where the heads were and blow the air in there first then switch over to water flush, and then I will rig up a pump to clean the jackets with the citric acid. Where do you buy it? Thanks....WA7OPY
Sat, Apr 14, 2018 7:20 AM
OzDozer
Reply to WA7OPY:
You can buy citric acid from drugstores, Walmart, Amazon and a range of food additive wholesalers. Citric acid is regularly added to many processed foods as an anti-oxidant. It's used in bread-making and often called "bread improver".
It's also used by craft-type people who manufacture home-made soap and "bath bombs". The citric acid is what gives bath bombs their fizz.
Here's a short list of some other sources;
Bulk Apothecary
Bulk Foods
Duda Diesel
National Chemicals
Nuts.com
The Sage
Soap Goods
Wholespice
I purchased a bulk paper bag of citric acid many years ago from a food additive wholesaler, I seem to recall it was about a 20lbs bag.
This bag was produced by the Archer-Daniels-Midland Company of Illinois, and I'm sure they still produce the same product. It's much cheaper to buy it in bulk, and it lasts for years if kept in a cool, dry, dark place.
Sat, Apr 14, 2018 7:35 AM
Bellyman
Send a private message to Bellyman
Reply to OzDozer:
Bulk Apothecary
Bulk Foods
Duda Diesel
National Chemicals
Nuts.com
The Sage
Soap Goods
Wholespice
You could try a mixture of Molasses and water , Its very good at dissolving rust of steel etc . Ive soaked metal objects in a brew for several l weeks and its cleans it up beautifuly , No rust left at all just clean bear metal so it should clean out a block very well ..
Sat, Apr 28, 2018 3:55 PM
WA7OPY
Reply to Bellyman:
I remember my dad 50 years ago telling me about Molasses and water to remove rust, I went the citric acid way and it worked really well. It was a little slow about 3 days of pumping around and around. The mix turned a very dark green after 2 hours, and then black. Flushed the engine 3 times before the water stayed clear. I don't think that one can find cheap Molasses around here, I tried to find some for goats a few years back with out any luck....WA7OPY
Sat, Apr 28, 2018 10:22 PM
