Recommended Grease for Track Rollers?
Showing 1 to 7 of 7 results
rhartwick
Send a private message to rhartwick
Not start a dreaded oil thread of sorts, but I always wondered what the modern equivalent is of the track roller grease recommended in the older manuals. They call it a tacky, sticky type grease. I just always have used a good grade of regular grease, mostly because that is all I ever have, but was wondering what I really should be using. I wonder if corn head grease is close to the original recommendation?
Wed, Mar 28, 2018 12:44 AM
corn head grease has been used by many people but 00 grade grease is what most people use--can be supplied by many different grease suppliers
use a volume type gun or a pressure regulator on a standard gun
Wed, Mar 28, 2018 1:30 AM
JackD6-5R
I have been using 0 grade grease for years, only reason it seems easer to get localy. most of my roller seals seem to leak and a little thicker seems to stay in better.
Wed, Mar 28, 2018 2:01 AM
bursitis
Reply to JackD6-5R:
i switched to corn head grease. john deere AG dealer carries it in regular tubes. i have some rollers that won't hold any oil that flows but the corn head grease stays put and only flows when there is motion,so it stays when parked and only exits just enough when operating to keep dirt out. i use the same lube schedule as the book recommends.
Wed, Mar 28, 2018 2:28 AM
truckun95
Send a private message to truckun95
Reply to bursitis:
Well I think it has a lot to do with what type of track rollers and their design. From the years of roller bearings to bronze bushings certain rollers seem to require different needs. Many types of grease is still available for purchase from the last 100 years. Greases and parts have improved over the years but sometimes the design and lessons of failures can help you pick the right grease you need. I still use the original type of grease on my Cat from the 20's it's certainly a different grease but still around today. The design of the bearings and their intended purpose is to move the grease but also to keep everything lubricated by the oils that are in the grease. Of course the newer the equipment gets the more easily it is to use more common greases today. I have never used corn head grease but when I was looking for grease it probably had more consistent properties to what I needed but never used it.
Wed, Mar 28, 2018 6:49 AM
Paso Bob
Reply to truckun95:
Chevron still makes the 00 track roller grease.
Wed, Mar 28, 2018 12:50 PM
Reply to Paso Bob:
Around 2005, I was out in the Bradford PA area, an old Operator out there gave me some containers that was "Steam Head Grease". He told me that it was the closest available replacement. Wish I could remember the brand name that was on the box? It does flow in warm weather but barely flows in cold weather. Nice thing is, it doesn't leak out of worn out Rollers! Its not correct probably, just throwing it out there!
Wed, Mar 28, 2018 6:21 PM
terrywelch_archive
Reply to drujinin:
All our traction engines use it. We get ours from a oil dealer. I know it sticks and sticks and does not wash off with the steam. I think we get it from Mobil
Wed, Mar 28, 2018 7:02 PM
