Paint Thinner to use with Cat Yellow Part No. 458-9576
Showing 1 to 7 of 7 results
dtucker
Send a private message to dtucker
I am getting ready to do some painting on a 2008 D4K Cat and bought a gallon of Cat Yellow Paint. No one at that cat dealer knows what type of thinner to use?
Thu, Mar 15, 2018 10:52 PM
STEPHEN
That's odd, cat used to sell thinner for their paint, I have a can will look and update
Thu, Mar 15, 2018 11:10 PM
Reply to STEPHEN:
Just another alkyd enamel, 458-9576 is manufactured by Sherwin Williams.
Solvent for Alkyd Enamel (Rustoleum)
Fast dry…..Acetone, Naptha
Medium….Toluene
Slow….Xylene
Very Slow…..Paint Thinner (Stoddard Solvent)
Fri, Mar 16, 2018 1:36 AM
TOGNOT
Medium….Toluene
Slow….Xylene
Based on your location\temperature\humidity - be aware. In my experience most paints are " ideally" applied around 70 F. Of course you can paint almost at any temp with correct combinations of chemicals and heaters etc, just something to be aware of. I recently sprayed some primer surfacer and directions stated not to apply below 50 F.
Also, I always add catalyst\hardener to oil base enamels. Makes the paint more durable and fuel resistant, in my opinion. 1\2 pint to one gallon ration. Tractor supply sells it - or try Amazon . In my warmer climate I have had good luck with acetone as a reducer
Fri, Mar 16, 2018 1:59 AM
dtucker
Reply to TOGNOT:
Thanks Old Magnet you are a wealth of knowledge. What ratio do you think I should mix if I use Acetone?
Fri, Mar 16, 2018 2:03 AM
Reply to dtucker:
I don't know of any fixed ratio. Get yourself a viscosity cup and thin accordingly for spraying. In general about 10% is considered maximum. That Cat paint may be close to spraying viscosity right out of the can but I have not used that product.
Fri, Mar 16, 2018 9:03 AM
steeltracs
Thank you received: 5
Always use a good respirator, especially when using hardeners.
Fri, Mar 16, 2018 10:10 AM
Thank you received: 25
Reply to steeltracs:
All of us get lax and sometimes forget some basics - just as a reminder, hope these help.
We all are very conscious of our engine air filters/cleaners - our lungs depend on clean air too and we tend to forget that at times, I am GUILTY!
Dust masks are not respirators, they do filter particulate matter depending on material of mask and size of particulate matter HOWEVER - they do not capture fumes or vapors.
Be sure seals are mated to filter and not leaking. (Cup hands over filters and try to inhale - should pull mask to face.)
Use proper filter for the product. (Fresh filters - if open and left in open atmosphere, they can lose effective properties. ( become contaminated)
Clean and protect your respirator after each use - plastic sealed containers work great, zip lock bag is ok for short time.
In Hazardous material situations - remember, the filters do not supply oxygen.
If you can smell the product - you most probably have a problem with the respirator/filters/seal.
Stay Safe -
cts
Fri, Mar 16, 2018 10:51 AM
| Hartley - South Australia
Newby Hall Tractor Fest
